Hi All,
I have flown my quad 12 times now, using the stock pid param as per 3.2.1
I get ~25min per flight with small HD Tube nose-mounted FPV cam.
I now want to attempt Auto-tune to optimize the rig.
 I don't think I am experienced enough to do PID tuning manually.
However, I read somewhere around that Auto-tune can fail on bigger, heavier quads, with low kv motors.
My build is based on the Tarot 650 Sport Quad Frame (X-config)
FC - PixHawk (3.2.1)
Motors - Tarot 4114  320kv
Props - CF 1550
ESC - HobbyWing Xrotor 40A
Batt - 8AH 6S
AUW : 3kg
1) I would like to know if Auto-tune can be done successfully on this build.
2) Do you recommend that I first upgrade to 3.3.3
Thank you for your valuable comments.
Gerhard
Cape Town, South Africa
You need to be a member of diydrones2 to add comments!
Join diydrones2
  • Hi Olivier
           Out of curiosity, what were you PID setting for that size x8?
    cheers.
    -Matt
    Olivier said:
    As an example here is a 12KG X8 with low 170KV motors (I fly it up to 18kg AUW) that successfully autotuned,  no issue at all.
    Cheers and good luck!
    3702219420?profile=original3702219559?profile=original
  • Thanks Henry for looking
    Couple things - I'm fairly certain on the loiter the throttle mid was set at 550. I know the alt_hold_fail.bin was 100%. But regardless of it if was 400,500 etc..I don't see why the throttle out for a moment drops to 200.  I have done alt_hold on other vehicles that were under powered and never ran into any issues.
    This vehicle as you mentioned is 4S and I'm using Lithium-Ion batteries. I'll have to check but I was fairly certain I had power module on there powering the pixhawk. I'll have to check again.
    I'll look into maybe if my firmware is old and see if there was a bug with alt_hold.
    • There was an issue with althold
      https://github.com/ArduPilot/ardupilot/blob/master/ArduCopter/Relea...
      line 16:
      "1) Bug fix for desired climb rate initialisation that could lead to drop when entering AltHold, Loiter, PosHold"
      ArduPilot/ardupilot
      ArduPlane, ArduCopter, ArduRover source. Contribute to ArduPilot/ardupilot development by creating an account on GitHub.
      • Thank you! I will have to confirm my pixhawk's are both up to date. I was fairly certain that my newer vehicle had most up to date firmware but will double check.
    • Wait Lithium ION?not LiPo?what is your C rating?
      • I need to double check but I think its a 4S5P pack so 17000 mah @ 2C rating(at most) I can draw about 34 amps. I think on a slightly less heavy version I flew it for about 25 minutes. I recently added about 300g which I think from calc's didn't pose a problem power-wise.
  • I followed steps on the wiki for setting thr mid and all other needed calibrations. On previous flights I looked at imu and saw that vibe looked great so I tried originally to go for loiter right off the bat (since I never had problem with alt hold before). On start of loiter it dropped like a rock and I barely was high enough to recover(see loiter_fail.bin). I then went back looked at all the data confirmed calibrations looked good and tried alt_hold instead of loiter. Same thing happened(see alt_fail.bin) ..the throttle in and throttle out do not match I've noticed. throttle out drops but throttle_in does not?
    I'd love to try autotune but If I can't figure out issue with alt_hold I'll never be able to tune it.
    alt_fail.bin
    loiter_fail.bin
    • Hi Steve
      You did not indicate what mode you were switching from before entering Alt hold and Loiter but I presume it was stabilize.  Depending on the weight of your multirotor, and the power of your motors/propellers your machine maybe over powered or under powered. Conversely the flight controller throttle output level may not be 50%.  Alt hold, loiter and autotune need the throttle out to be at 50%. So perform a 1 minute hover, down load the log and see what value the throttle out is at. Lets presume throttle out on your multirotor is at 60%, this means your multirotor is under powered. So when you switch from stabilize in hover mode to loiter the flight controller switches throttle out back to 50% and hence your multirotor will lose altitude. Again if the stabilize test hover mode throttle out is 60% enter this value into the Throttle mid setting. Now the flight controller knows the actual power required for your multirotor and switching flight modes should be almost transparent. There is one other setting you may want to adjust, this is throttle deadband, this effects the amount of deadband of your throttle stick when hovering in Alt hold or loiter. I have my pixhawk set to 75 and works pretty well. Once alt hold works correctly you can start Autotune. If the throttle is not set to the 50% or in your case a modified value autotune wont start. In my case I had to fiddle a bit with the throttle stick in order to get autotune going.
      Hope this helps
      • Just had a look at your Loiter fail. bin. Sorry I missed it. Your hover is around 55% so your machine is under powered. Having the Throttle mid at 40% makes the situation worse. Enter 55% into the Throttle mid setting. You could consider upgrading to the next Lipo battery IE S4 to S5, or S5 to S6 to give your multi more power.
        Cheers.
        • I should have looked at your log earlier so I apologize, I can see you are running a 4S lipo the cutoff voltage for safety of your machine for 4S should be in the area of 14.4 but no lower than 14 volts. You reach this in the first 3.5 minutes. I think your battery miliamp capacity is too small. I also notice you flight controller voltage is quite dirty and too low. It appears you may not be using an APM power module? Pixhawk needs 5.3 volts because of the internal hardware has an isolation diode which drops the voltage by .3 volts. Your VCC low peaks are at 4.85 volts.
          I will go to bed now. Its night time in Auz.
DIY Drones via Twitter
Welcome to the new DIY Drones design!. You may have noticed that DIY Drones looks a little different today. That's… https://t.co/cg2EmeDGMQ
12 hours ago
New! Online Training on Drones for Disaster Response https://t.co/brqRuujjY2
yesterday
DIY Robocars via Twitter
https://t.co/8EMCvYW6oz
Tuesday
RT @OttawaAVGroup: We are going to try something new this week. We will be having a drop-in style meeting Wednesday @ 7-9pm EST. Pop in and…
Monday
RT @tawnkramer: Thanks Everyone for another fun virtual race! Amazing Ai racers competing head-to-head, Virtual Makers Fair event. Catch us…
Sunday
RT @make: Find out the latest from @diyrobocars at 10am PT from @chr1sa of @3DRobotics on Virtually Make Faire! #makerfaire #maketogether #…
Saturday
RT @Heavy02011: Join us Saturday online: Virtual Race League: @DIYRobocars Race #2 - Parking Lot Nerds https://t.co/aJUu4sdutx #Meetup via…
Saturday
RT @donkey_car: Yay, we are part of the virtual @makerfaire with @diyrobocars. Come see our race or better yet train a model and race with…
May 21
RT @chr1sa: The @DIYRobocars Virtual AI Race is going to be part of the virtual @makerfaire on Sat! https://t.co/wnMDAboLID
May 20
RT @tawnkramer: Please join us next week for our second DIYRobocars online race. We will be using a new Mountain Track course! https://t.co…
May 19
RT @SmallpixelCar: I realized that the size of the cones in @diyrobocars is known. If we can detect the bounding box, which can be done wit…
May 19
RT @chr1sa: Our next @DIYRobocars autonomous car virtual race is this Saturday. Sign up here to compete or just spectate on @Twitch https:/…
May 19
Definitive Guide to Setup Drone Delivery System https://t.co/7ibwcgF24h
May 19
RT @DAVGtech: The next @diyrobocars virtual robocar race is this Saturday. One of many interesting issues we are taking a stab at is "how c…
May 18
RT @chr1sa: cc @DIYRobocars @donkey_car https://t.co/ewbyqZ3xC0
May 18
RT @chr1sa: This is the technique that many of the @DIYRobocars racers use to estimate their localization position on the track https://t.c…
May 18
