hi guys, this time im back because i detect some issue refer to battery monitor system in last mission planner.
On battery tab in APM setup screen its impossible write manualy any values..
and the battery voltage indicated is for example : 10.66 v but if i test the battery with my manual voltimeter it show me 11.35 v !!! why is that diference in mesurement?
my settings are: Monitor 1:3 Cell Capacity 6000
(I have a lipo battery Dualsky 3 cells 11.1v, 6000 capacity.
franco.
I am using AttoPIlot sensor. Had to rescale the voltage divider ratio to get the right values too.
The difference in measurements may be explained as a voltage drop, because when you define voltage using multimeter - it doesn't cause big current flow (and a voltage drop as a consequence).
Hi
Faced the same issue and I changed the value of the Voltage Divide Ratio (Rescaled it).
//#define VOLT_DIV_RATIO 12.6
#define VOLT_DIV_RATIO 14.364 //scaling 1.14 times
# define BATTERY_EVENT ENABLED
# define LOW_VOLTAGE 10.5
# define CURR_AMP_PER_VOLT 27.32
I am using AttoPilot voltage and current sensor. Now I am approximately measuring the exact values
