Hi ,
We have a requirement to photograph and stitch the geo coded photos of large areas ( ~100 sqkm) and tag certain objects in these images . Once setup flying and feeding the photos must be automatic , only battery change should be required for a manual intervention.
Please suggest a good open source solution and components and softwares needed
  • Your in over your head bud, I can tell by the question.
  • Hi Ajay,
    We expertise in doing large areas in India. We have experience of doing upto 450 sq. km. (already completed) areas using UAVs. You can get in touch with us at info@indrones.com to discuss your requirement. I think we can be of help here.
  • we have close to 500 sqkm of forest area to cover and low resolution aerial 2D maps are enough , what would b the best stitching open source software needed which can work with E384
    ECODRONES said:
    Yes, you can.
    Ajay Krishnan said:
    I can see they use mission planning software, will we able to load the maps generated to our dashboard for tagging purposes
    ECODRONES said:
    I do recommend E384 or E386, from Event38 Unmanned Systems, www.event38.com
    Cheers!
    Best Solution for photographing and mapping large areas
    Hi , We have a requirement to photograph and stitch the geo coded photos of large areas ( ~100 sqkm) and tag certain objects in these images . Once…
  • Yes, you can.
    Cheers!
  • I can see they use mission planning software, will we able to load the maps generated to our dashboard for tagging purposes
    Cheers!
  • Look into the Lynx by Swift Radioplanes: www.SRP.aero
    3 hour endurance for a hand launch drone! plus durable Kevlar construction
  • I do recommend E384 or E386, from Event38 Unmanned Systems, www.event38.com
    Cheers!
DIY Robocars via Twitter
Friday
RT @_JonMyer: 🏎 We need your help in naming my #AWS DeepRacer Underground Track 🏎 @davidfsmith's track is going to be referred to as 𝗔𝗪𝗦 𝗗…
Oct 22
RT @gclue_akira: 仕事もおわったし、電脳化にとらい #マリオカートハック https://t.co/4IU90hCLgm
Oct 22
This is the hashtag to follow all the people in Japan who are hacking the new Nintendo Mario Kart with the real AR… https://twitter.com/i/web/status/1319281354664677376
Oct 22
RT @gclue_akira: @chr1sa @diyrobocars jupyter mario https://t.co/P0oHdjlCRq
Oct 22
RT @_JonMyer: 🚨Our 1st AWS DeepRacer Community Race is Underway on http://twitch.tv/aws 🚨 Join us to find out which member of your commu…
Oct 20
Oct 19
RT @BackyardRobotcs: After an admittedly long wait, the new Tinymovr R3.3 motor controller is now available https://tinymovr.com 🥳
Oct 19
RT @_JonMyer: 🏎 1 hr left before the #AWS #DeepRacer Community 🏎 Top 5 Race tomorrow LIVE on Twitch 1st Place = $50 Amazon GC or AWS Credit…
Oct 19
Oct 16
Oct 15
Oct 14
RT @davidfsmith: Race virtually with The AWS DeepRacer Community Race and then join us on the track to see how your times compare on the ph…
Oct 14
Oct 14
Hiroki Tanaka liked Hiroki Tanaka's profile
Oct 13
RT @breadcentric: It's now!
Oct 13
