Best tricopter layout
I see arducopter has two possible tri-copter options; which is best? And what does it mean when the second option "doesnt need a code change"?
It's for a small 300mm foldable - the HK trifecta to be specific.
  • Can you share the PID settings that is used on APM. I havent done my maiden yet due to this. Do you have any approved PID settings for trifecta?
  • If all of your props are spinning in the same direction, your Tri will have a constant roll offset (because the tailrotor is constantly deflected to compensate for the additional torque).
    Some people find this annoying. This is what happend to my tri, otherwise, it flies just fine :D.
    Let us know how your maiden went.
  • 3701926316?profile=original
    Built it...a problem with the servo not returning to centre needs fixed before maiden. Oh, and the FPV wired in. A very tight fit for everything.
    https://storage.ning.com/topology/rest/1.0/file/get/3701926316?profile=original
    • Euan - how did you go with you Trifecta? I am halfway through a build on one of these at the moment and am keen to know about your experience.
      • Not that great if I'm honest.
        I had to decouple pitch and roll and tune them seperately. I can get a stable D rate of 0.003, which seems to be the most APM can cope with at this form factor (I have the same in a mini hex and a quad). I am still experimenting with PI rates; I can get it to "full sticks", but it's a long way from being "locked in".
        Pitch seems to be the main issue; in high speed turns it wallows a lot. Straight ahead, not so bad, but throw in some roll, and it starts to oscillate on pitch.
        • I finally repaired the diode issue with my Mini APM V3.1s (Purchased from RTFQuads) and finished setting up my little trifecta.
          3702783468?profile=original
          To be honest I am pretty happy with the results so far.
          I started with some basic tuning in the living room that provided reasonably good flight characteristics (just a little wag and wobble).  I did my first autotune flight today and got a pretty nice tune first go!  There is still a little waggle in the tail, but it otherwise feels just as solid as any of my other multis.
          BTW - Perhaps your choice of prop is limiting the quality of the tune you can achieve. NOTE - I initially assembled with 7x4 HQ props but it was oscillating all over the place and quite a bit over powered with those props, so I switched to 6x3 Gemfans.  Notably, the osilations reduced dramatically when switching to the smaller and more flexible Gemfans (without any change to the PIDs - which I don't quite understand).  I will be interested to see whether the oscillation return when I switch back to the 7x4 HQs (and will report back in case you are interested).
          • soy de venezuela me interesa comunicarme Directamente con su persona. Tengo un desarrollo de DRON. pero lo que no quiero es que lo utilicen con fines belico. puede capturar aeronaves en pleno vuelo.si se desarrolla a escala como un ALA DELTA.y capacidad de remolcador dependiendo su desarrollo. acabaria con todo los aviones del mundo.SU NOMBRE ES EL VUELO DEL MURCIELAGO. IDENTICO SU CAPACIDAD DINAMICA DE VUELO. ELTOVY@GMAIL.COM
            vuelo.si - This website is for sale! - Vuelos Resources and Information.
            This website is for sale! vuelo.si is your first and best source for all of the information you’re looking for. From general topics to more of what y…
        • Hi Euan,
          Thanks for your update. It is a shame to hear that you have had limited success. It seems you are not the only one though, as it appears that APM powered trifectas are somewhat difficult to get right. I am not actually aware of anyone who has achieved a well tuned setup to date.
          My trifecta build is now on hold unfortunately. It appears that two mini APM V3.1s I purchased a while back have manufacturing faults relating to incorrect diode selection. The problem resulting from this issue is a full 1VDC drop between my power module and reciever, which is no good at all. I am awaiting a response from the supplier at this point in time.
          Having gone to some trouble fitting everything including a cut down power module into the limited internal space available in the Trifecta I am quite keen to persevere with using an APM on this frame, but may perhaps end up grabbing a Naze32 to get this cool little frame in the air.
  • I wonder why APM:Copter does not support Y6 with one arm forward and 2 arm backward like a reverse Y. Such configuration may result in less drag than Y.
  • Y6
DIY Robocars via Twitter
RT @Heavy02011: ⁦@diyrobocars⁩ : A Home-brew computer club* for Connected Autonomous Driving. talk at #piandmore ⁦@PiAndMore⁩ on Jan 23rd h…
Saturday
RT @a1k0n: New blog post! Deep dive into my ceiling light based localization algorithm which runs in 1ms on a Raspberry Pi 3: https://t.co/…
Saturday
Great new guide to using @donkey_car https://custom-build-robots.com/donkey-car-e-book-en
Saturday
RT @chr1sa: The next @DIYRobocars virtual AI race is tomorrow morn at 9:00am PT. You can watch live on Twitch https://www.meetup.com/DIYRobocars/events/275268196/
Friday
New version of Intel OpenBot! This resolves many of the issues with the first version, including a much smoother tr… https://twitter.com/i/web/status/1352395636369313798
Thursday
DIY Drones via Twitter
Using ArduRover with an RTK GPS https://ift.tt/2N9I3RO
Jan 18
Jan 18
Jan 18
Jan 15
Jan 15
Jan 14
RT @Heavy02011: @diyrobocars : A Home-brew computer club* for Connected Autonomous Driving on Jan 23rd, 2021 https://www.meetup.com/Connected-Autonomous-Driving/events/275728684/ #Meetu…
Jan 14
Jan 14
David Hori liked Isabella Domi's profile
Jan 12
RT @Heavy02011: ⁦@diyrobocars⁩ Autonomous Driving Assembly at #rC3. join us at https://rc3.world/rc3/assembly/diyrobocars-f1tenth/ ⁦@f1tenth⁩ ⁦@DAVGtech⁩ ⁦@DWalmroth⁩…
Jan 11
RT @chr1sa: New car designs coming for our next @DIYRobocars @donkey_car virtual race on the 23rd. Choose any one you want at race time Le…
Jan 11
