Hello,
I've been confronted with a big problem.
I am using APM2.5 + the Power sensor board to provide the +5V.
The output JP is removed to provide seperately power to output (gimbal servos).
I experimented with a new PPM converter which didn't work yesterday. The guy who build it said I shoud check power. I did and found 4,4V on the input line.
Then I saw smoke and now lights are out for the APM2.5.
The power-meassurment-module provides 5,3V!
The APM2.5 is still alive, but only when powered directly by ESC on the Input line.
So is there any fuse on the power supply/meassurement port?
I don't know what to do. I am devestated. I need some ideas. Please.
  • What's the fuse part number ?
  • Same problem, different solution.
    I could only arm my APM 2.8 when connected through a USB cable.
    I got ~5v on both sides of the fuse, but only on the bottom (exterior) side of the diode.  top (interior) side was dead.
    I was looking at replacing/bypassing the diode.
    I'd previously used ESC's (yes, multiple) and then a UBEC to power the FC.  When I instead used the power lead from an APM power module, I then got ~5v on both sides of the diode.
    I assembled the works and it all arms/flies fine now.
    Worth a shot...
    Unsure of the explanation, but it proved a relatively simple fix.
DIY Robocars via Twitter
Jun 25
Jun 25
Jun 16
Jun 13
Jun 13
Jun 13
Jun 7
Jun 7
May 28
May 15
May 14
May 13
May 13
May 11
May 8
May 8
