Hi all!
I´ve seen enough photos of people having cut themselves with their copters, to start thinking about building a fully protected multicopter.
Having searched for something similar, I found the safeflight copter, which is not produced any longer.
Reading about flight times and concerning the additional weight, I realised that it would not be an easy task, to build a multicopter, that has acceptable flight times (more than 10 minutes) and still is agile enough to have fun AND small enough or with easy disassembling, to be transported.
Additionally, I thought about giving it a good look with a kind of thermoformed housing.
Has anyone ever made a really safe housing (like the safeflight copter)?
I found some woven thread used to catch big fish, while fishing. It´s a half millimeter thick and holds about 40 kilos. That might be suitable for adding a netting over the copter, so nobody can stick their fingers into the housing of the props.
What´s really annoying, is that I have absolutely no idea of how to add that netting on the housing of the props. Glue? Weaving like in a badminton rack? It should be removable, since you have to change the props from time to time.
For the housing itself, I have made some styrofoam circles, but they seem to be to brittle to withstand a small crash. I thought about having a small layer of glass fibre added around them.
Whatever I think about, adds a lot of weight to the copter, so I thought about setups, that would suit my needs.
But I´m not sure, wether to build an Y6 or X8 copter with 10 inch props or simply a quadcopter with 15 inch props, trying to make the housing of the props as lightweight as possible.
Discussion and comments are welcome and higly appreciated!
Thank you,
Steffen
Forget that idea. I´ve ordered some and they are not very stable. Won´t work.
Hi J Smith.
Thank you for your answer. Reading about a real solution you have in mind, I got very curious, what that might be. I hope you find a way to get that on the market soon.
For now, I´m going to add some of the following:
http://www.hobbyking.com/hobbyking/store/RC_PRODUCT_SEARCH.asp?strS...
Not the perfect solution, but better than nothing, as long as I still need some more flight training.
I´ve had some mail contact with the guys from Dronewerx concerning the PG-Y6
Here´s the link:
http://www.google.de/imgres?imgurl=http%3A%2F%2Fwww.suasnews.com%2F...
The frame is not yet available and since its made from carbon fibre, I think it´s going to be expensive.
Your post about the "real solutions" makes my head work already and I hope, I can sleep tonight :-)
