during the COMPASS_MOT calibration I burned the wires with the DF13 plugs from the PM to the Pixhawk.
I'm lost because it is the second time this happened with two different FC on the copter.
I'm using 6S Lipo and a PM that reads DC in 2S - 7S - 5.4V, 3A
It looks (pic) the two ground wires smoked most.
Please- I could use a hint on whats my error is. The copter formerly flies, it is a rebuild.
Tags:
Many power modules don't support 6S...is it an attopilot, or (maybe) the HK module?
It is the PM that is delivered with the Pixhawk or the CUAV FC.
So they're too weak for 6S.
@Andre = I don't understand the ESC thing. I have (hexacopter) ESC with two wires (gnd and signal). How that could fry the ground wires between the PM and the DF13 power plug to the Pixhawk?
Bernardo said:Can I make a derivation and feed one of the the + and - over a 5V BEC (2S - 8S)??
Mossbackfarm said:Many power modules don't support 6S...is it an attopilot, or (maybe) the HK module?
ok, found the cause of the problem:
the hint with the "poor ground connection" is right, It was even worse. Due to a crash into an apple tree one or more motors continued spinning for a while (perhaps RTL).
That burned the main conductor track on the PDB.! It acted like a fuse. (See pic)
So ALL the current flows over the two 26AWG wires between the PM and the power connector to the Pixhawk. wow!
I found it because after Andre mentioned the ground thing I test all the ground wiring with a multimeter und suddenly found no continuity from the negative Lipo plug (in) to the negative connector of a motor at the end of the arm. :o
So I opened the shell of the PDB an saw the burned track!
Now solved, ready to take off again. Thank you very much for writing Andre and Mossbackfarm !!! :)
45 members
1472 members
282 members
470 members
57 members
Powered by
