I know some basic of aerial photograph for mapping and survey but I 'd like to know if there is a fomula to calculate waypoints in function of airplane height, track spacing, area coverage etc. Where can I find sources to guide me for this formula? Thank you.
MP planner has a nice tool to calculate your coverage based on lens and digital back.
or
you can fly in stable mode and take a photo at 100' above ground and measure the image size.
once you have the image size, you can develop your waypoint distances based on a forward gain percentage. Pending on the the terrain or features on the ground you can apply a 60%-80% fg strategy for image overlap. I would recommend 60% or better. You apply the same strategy for your sidelap as well.
I recommend the "manual of photogrammetry" for a detailed understanding of the mapping industry.
send me your image coverage area and I can develop your math if you need help.
good luck :)
- Or, place a horisontal + vertical ruler on a wall, take a photo from 10' distance, multiply measures by 10 ;-)
I mapped my floor as a test when I first got started from about 2'
You have to fly your camera sometime :)
Hi GeoBlu,
Is it the MAP TOOL > CAMERA ?
If yes, could you explain how to get usefull values from it? Example, I'm about to use the canon sx260 hs camera.
