Hello, I've flown the Iris + and canonS110.
In trying to geotag photos sigueitne I get the error:
CAM Msgs and Files discrepancy. Check it!
And the images come to me in the wrong position, sending the images uan
A must this problem as solved.
Thank you in advance for your support.
Use Pix4D to georeference your images. It's much more accurate. You must use time offset in mission planner if you have a an uneven amount of CAM messages and images.
Thanks po your valuable and appreciable response Pix4D is difficult because I do not think you will use for your $$, follow your second tip.
What do I do so that everything goes well and not have such problems, some tips.
Cheers
