Camera Servo Wiring
I'm not sure why I can't wrap my head around this, but I'm trying to attach the servos to RC 10 and 11. (I'm using the power module, JP1 is off)
Obviously just plugging them in causes a brownout, But to power them separately I would  need to pull both the power and ground plug and hook them to a BEC. But the servo is going need the signal wire and ground to function....So how exactly do I wire this to get it working?
  • You sure the signal wire needs ground?  I've run signal wires solo before.  You could just create a bridge between the apm GND bus and the Battery/BEC GND.
