can i build a quadcopter with this spec.
hello everybody. i need suggestion
i wanna build a quadcopter with this following spec.. can it be done?
1. q330 totem frame
2. esc 20a
3. motor 920kv
4. prop 9450
5. battery 5200 mah multistar..
just wondering can i build with this spec? i dont really like 380 frame, so i go for smaller frame.. thanks for any advice.. happy december
  • The rotor combo is going to spin to slow to compensate PID effect on small frame.
  • thanks for your help mate, it really help.. i have build using f450 and also tbs clone frame before.. just wondering if i build it using light, and also much smaller frame with stock equipment. i will go through the link that u give. thanks a lot for helping..happy flying
    Crady von Pawlak said:
    Hi, Andi.  Your specs may be a bit optimistic for that frame.  I'd suggest perusing this group to get an idea of what others have done with the Totem Q330
    https://www.rcgroups.com/forums/showthread.php?2371749-HMF-Totem-Q330
    Also, if you're new to building then I strongly urge you to get a paid subscription to eCalc.  It's only a few dollars for short-term use and can quickly help you determine the optimal balance of motor, prop, ESC, and prop size and type for a given frame and weight.
    http://www.ecalc.ch/xcoptercalc.php?ecalc&lang=en
  • Hi, Andi.  Your specs may be a bit optimistic for that frame.  I'd suggest perusing this group to get an idea of what others have done with the Totem Q330
    RC Groups
