Is it possible to upload the waypoint info to APM once at startup (using mission planner) and then let it complete the mission without (or beyond the range) of the telemetry system?
I think it should be possible. I just cant find any documentation for the same.
Vikrant
  • u4eake,
    Maybe the solution to really long distances is to use 2G/3G/4G telemetry? One of the phonedrone cards and a mobile phone sitting on the plane acting as a missions planner. I guess the SW is not there yet.
    Vikrant
  • Yes, I do understand the risk of going beyond the range of telemetry control.
    I just wanted to understand what are the limitations. No way am I going to try this now (I'm just getting started with APM), but maybe in the future :)
  • T3
    You can fly beyond telemetry and beyond TX range. Hell you can fly until the battery dies and land. But good luck finding the copter. One guy flew under auto with FPV and he went beyond control, but could still watch the flight. Pretty cool.
  • Thanks for your replies guys!
    So if RTL is the last command of the mission (and GPS got the correct location for Home and there is enough battery for the mission and ...) it is ok to go out of the range of telemetry?
  • Not sure I understood correct your question, but I can say that when you are in Auto mode (with waypoints), even you are beyond the range of telemetry, the mission will continue as per waypoints. You need to considered if you have any failsafe defined and also you can not more trigger RTL or Stabilize or any other mode when you are  beyond the range of telemetry.
  • yes. when you hit write, it loads the waypoints onto the apm board, and then when you go into auto mode it flys the mission. even if you fly out of your tx range, it can complete the mission (depending on failsafe setup)
DIY Robocars via Twitter
RT @SahikaGenc: AWS DeepRacer & Hot Wheels Track https://youtu.be/4H0Ei07RdR4 via @YouTube
Monday
Sep 8
RT @davsca1: We are releasing the code of our Fisher Information Field, the first dedicated map for perception-aware planning that is >10x…
Sep 8
RT @SmallpixelCar: How this works: 1)object detection to find cones in single camera image, 30 frames/sec on @NVIDIAEmbedded Xavier. 2)comp…
Sep 8
RT @SmallpixelCar: Use two color cones to guide the robocar. No map needed, on onsite training needed. Just place the cones and it will fol…
Sep 7
Sep 7
RT @roboton_io: Great to see http://roboton.io running at 60fps on the cheapest #chromebook we could find! #edtech #robotics #educat…
Sep 3
RT @openmvcam: Crazy in-depth article about using the OpenMV Cam for Astrophotography: https://github.com/frank26080115/OpemMV-Astrophotography-Gear https://t.co/BPoK9QDEwS
Sep 3
RT @openmvcam: Hi folks, it's finally here! Our first draft of our Arduino Interface Library is out! It works over SoftwareSerial, Hardware…
Sep 3
RT @chr1sa: Please let them have an open API. This would be perfect for @DIYRobocars races https://twitter.com/NintendoAmerica/status/1301513099707658246
Sep 3
RT @SmallpixelCar: Lanenet pretty much used all my GPU power on @NVIDIAEmbedded Xavier since I optimized with tensorRT. I need to run anoth…
Sep 3
xemone liked Max Gilson's profile
Aug 31
RT @LyftLevel5: Our @kaggle competition on Motion Prediction for Autonomous Vehicles is now live! Experiment with the largest-ever self-dri…
Aug 24
RT @chr1sa: Our next @DIYRobocars virtual AI car race will be on Sept 26th. Sign up here https://www.meetup.com/DIYRobocars/events/272786977/ https://t.co/UENKGSOWO8
Aug 24
New ready-to-run @NVIDIAEmbedded JetRacer car from Waveshare. Perfect for the next @diyrobocars race as soon as we… https://twitter.com/i/web/status/1297960223013867520
Aug 24
DIY Drones via Twitter
RT @chr1sa: The US government just approved 5 US-made drones for purchase, all based on the @Dronecode @PX4Autopilot standard. Great news f…
Aug 20
