Hi guys!
I am currently doing an underwater drone project. i am trying to connect the drone with an flight controller chip to an brushed motor to stabilize the underwater submarine is it possible to use brushed motor?
NO!
Hi OG!
Any particular reason to this? sorry i am new to this hobby!
Please do some research on how motors work and different types of motors !
If you use an ESC for brushed motors, why not.
https://www.aliexpress.com/item/Waterproof-320A-Brushed-ESC-Electro...
Hi Armin!
  Am currently using an ECS(MC230CR-Futaba) right now, but the current issue right now is when i pluck it in it just spins away!
I guess you need to adjust the PWM values. Also consider that those ESCs usually also have reverse. I would expect at a 1.5ms PWM pulse with the motor stops. Since multirotor ESCs are usually stop at a 1ms pulse with your flight controller is sending a 1ms pulse with on the beginning, so your motor probably turns in reverse now.
