Good evening,
Since couple of time I'm doing some trials using a SX230 camera installed on a X5 wing.
The results seems to be ok, but I need to gain more trust :) that why I need your support regarding good sample pictures done by you.
To be more precise,please post some of your pictures, that you consider that are ok in terms of quality. If possible please point also the camera settings.
Here are some examples from me - 100m altitude (any advice is welcomed):
Hi Alex
We use a X5 with a canon elph520. 10mpixel . It works great but you need to refine your settings to get the good result.
Asa 200
Speed 1/1500 or less
WB sun
Turn off view image
Select single shot
Most important. Your images are overexposed so you must close the aperture by 1/2or3/4 stop
And lock the focus at infinity
Now the camera will react faster( no focusing ) any the image will be much clearer
Hi Alex, what setup you use on Canon ? What configuration you use for take this pictures with your X5 UAV ?  Thanks !
Hi Rafael,
I'm using as CHDK script this : http://chdk.setepontos.com/index.php?topic=10822.0
All the values are at default except shutter speed that is at 1/1600.
If you need more info let me know.
Hi David,
Can you please post some sample pictures?
Thank you.
Alex,
Thank's for this script. I will try it on the weekend. I am also flying an X5 and would be interested to know how you mount your camera to reduce vibration. I mount a canon IXUS 132 in soft foam.
Hi , below a picture with the layout :
A490 on with CHKDK on custom nadir spring mount on Hexa-B.
Shot at 50m alt.
All props super balanced and Ardupilot DuBro foam mounted.
ImageDescription -
Make - Canon
Model - Canon PowerShot A490
ComponentsConfiguration - YCbCr
CompressedBitsPerPixel - 3 (bits/pixel)
ShutterSpeedValue - 1/636 seconds
ApertureValue - F 2.99
ExposureBiasValue - 0.00
MaxApertureValue - F 2.99
MeteringMode - Multi-segment
Flash - Flash not fired, compulsory flash mode
FocalLength - 6.60 mm
UserComment -
FlashPixVersion - 0100
ColorSpace - sRGB
ExifImageWidth - 3648
ExifImageHeight - 2736
InteroperabilityOffset - 3320
FocalPlaneXResolution - 15136.93
FocalPlaneYResolution - 15116.02
FocalPlaneResolutionUnit - Inch
SensingMethod - One-chip color area sensor
FileSource - DSC - Digital still camera
CustomRendered - Normal process
ExposureMode - Auto
White Balance - Auto
DigitalZoomRatio - 1.00 x
SceneCaptureType - Standard
Maker Note (Vendor): -
Macro mode - Normal
Self timer - Off
Quality - Fine
Flash mode - Not fired
Sequence mode - Single or Timer
Focus mode - Single
Image size - Large
Easy shooting mode - Full Auto
Digital zoom - None
Contrast - Normal
Saturation - Normal
Sharpness - Normal
ISO Value - Auto
Metering mode - Evaluative
Focus type - Auto
AF point selected -
Exposure mode - Easy shooting
Focal length - 6600 - 21600 mm (1000 mm)
Flash activity -
Flash details -
Focus mode 2 - Continuous
Auto ISO - 1
Base ISO - 100
Sequence number - 0
Flash bias - 0 EV
Subject Distance - 0.00
Image Type - IMG:PowerShot A490 JPEG
Firmware Version - Firmware Version 1.00
Image Number - 1010042
Owner Name -
Sharpness (EOS 1D) - 0
Directory index (EOS 450D) - 57344
T
Hi, you were right.
I have used -1 stop ( maybe too much) and the pictures are better:
At next flight I will try -0.66  to see the difference. On the post above, by "Asa 200" did you mean to say ISO?
Thank you.
Hi Alex
Yes, you are correct, it is also better to mount the camera along the body, its easier to follow the pictures when they are in a larger file and the stitching becomes better.
Richard, thanks a lot for the sample picture , very good quality!
My big disadvantage is that my wing is flying at 60-70 km/h while taking pictures.
I will put on my Santa Claus wish list :) a hexacopter.
Woops. Sorry.
Practice stalls.... :-)
And be good for Santa.
Hello,
Today I had an interesting experience, I have done a flight at around 12:00h , very sunny outside, and I have observed that on the majority of the pictures there is somehow a reflection of the sun. The flight was done over a wheat field.
What are the hours that you think that are the best for survey missions?
