Channel remaping (warning with changing mode)
Hi to all.
I'm flying copters over 3 years. Had OpenPilot, Multiwii, and ported to STM32 multiwii.
This time i've started new project with arducopter.
I've called it Gerris.
I've had plan to use AIO, but I didn't like it and changed plan to use APM.
_IGP3093.jpg?width=1005
It's almost ready. Only need to cut motor cables and need to setup APM.
But, I have some small problem, which stopped my progress.
I have JR PCM9X radio with FRSKY. I'm planing use RX with enabled CPPM. But with this combination is one small problem with channel order.
So my question is. How to change channel mapping in APM ?
I've tried changing modes in JR (1,2,3,4) but without success.
  • Page 142 of 3.0.1 release discussion.
  • Hi Bartek, I had the same issue. You can alter the code and download to your amp via arduino ide. My discussion is here
    http://www.diydrones.com/m/discussion?id=705844%3ATopic%3A1145083
    There is a channel mapping function coming out I think in the next release or so.
    If you choose to alter the code (which is only swapping a couple of numbers around) if you are on 2.9.1 you will only have to do as suggested by Randy in the link above. If you are on 3.0.1 you also have to swap 2 other numbers as mentioned around page 140 ish of the 3.0.1 release discussion. I fly mode 1 but have to set the tx to mode 2 for it to work for me.
    regards
    Alex
DIY Robocars via Twitter
RT @SahikaGenc: AWS DeepRacer & Hot Wheels Track https://youtu.be/4H0Ei07RdR4 via @YouTube
Monday
Sep 8
RT @davsca1: We are releasing the code of our Fisher Information Field, the first dedicated map for perception-aware planning that is >10x…
Sep 8
RT @SmallpixelCar: How this works: 1)object detection to find cones in single camera image, 30 frames/sec on @NVIDIAEmbedded Xavier. 2)comp…
Sep 8
RT @SmallpixelCar: Use two color cones to guide the robocar. No map needed, on onsite training needed. Just place the cones and it will fol…
Sep 7
Sep 7
RT @roboton_io: Great to see http://roboton.io running at 60fps on the cheapest #chromebook we could find! #edtech #robotics #educat…
Sep 3
RT @openmvcam: Crazy in-depth article about using the OpenMV Cam for Astrophotography: https://github.com/frank26080115/OpemMV-Astrophotography-Gear https://t.co/BPoK9QDEwS
Sep 3
RT @openmvcam: Hi folks, it's finally here! Our first draft of our Arduino Interface Library is out! It works over SoftwareSerial, Hardware…
Sep 3
RT @chr1sa: Please let them have an open API. This would be perfect for @DIYRobocars races https://twitter.com/NintendoAmerica/status/1301513099707658246
Sep 3
RT @SmallpixelCar: Lanenet pretty much used all my GPU power on @NVIDIAEmbedded Xavier since I optimized with tensorRT. I need to run anoth…
Sep 3
xemone liked Max Gilson's profile
Aug 31
RT @LyftLevel5: Our @kaggle competition on Motion Prediction for Autonomous Vehicles is now live! Experiment with the largest-ever self-dri…
Aug 24
RT @chr1sa: Our next @DIYRobocars virtual AI car race will be on Sept 26th. Sign up here https://www.meetup.com/DIYRobocars/events/272786977/ https://t.co/UENKGSOWO8
Aug 24
New ready-to-run @NVIDIAEmbedded JetRacer car from Waveshare. Perfect for the next @diyrobocars race as soon as we… https://twitter.com/i/web/status/1297960223013867520
Aug 24
DIY Drones via Twitter
RT @chr1sa: The US government just approved 5 US-made drones for purchase, all based on the @Dronecode @PX4Autopilot standard. Great news f…
Aug 20
