CLI access via Mission Planner is Impossible
Hi folks,
I'm trying to download the logs from the flash on the APM 2 (v2.73) using the CLI tool in Terminal...it doesn't seem to be possible.
I've tried the sequences below, but they all seem to be inhibited by the incredibly long connection process the Mission Planner undergoes, which is probably 30-45 seconds.
Sequence1
  1. MP open, at the terminal tab.
  2. Connect APM via USB
  3. Click connect on MP
  4. Spam <enter>
  5. Nothing happens on screen.
Sequence2:
  1. MP open, at the Flight Data tab.
  2. Plug in APM to USB.
  3. Connect to my com port from this screen, wait 40 seconds for the MP to respond, then connected.
  4. Switch to Terminal tab.
  5. Nothing rolling by on the screen.
  6. Hit the Terminal tab button again
  7. Screen clears, then a chunk of the ArdupilotMega 2.73] prompt appears but does not respond to button pushes.
I can still use the MP conventionally without issue--for tuning and config and such.  Also works with the 3DR radio just fine.
This MP failed to upload APM firmware, too.  I had to use the APM patch of Arduino to get the writes to verify--MP failed every time.
As for alternative CLI access, I can get to APM's CLI with no issues via SecureCRT and PuTTY.  To avoid losing my logs from this morning's maiden flights, I'm just running dump out of putty and saving the mess into a .log file... I'm not sure what I'll need to do to graph and analyze this later, but at least I'll have the data.
So, I suppose I have to challenges to unravel:
  1. How do I get MP CLI to function reliably?  Whatever I'm doing wrong is rendering it useless.
  2. How do I trim and save these log files so the APM native applications (like MP) can read and understand them?  The interpretation tools are great!
Any help you folks can offer is much appreciated!
spag
  • I tried uploading 2.74b tonight and encountered this error--perhaps it's related?
    https://storage.ning.com/topology/rest/1.0/file/get/3692780693?profile=original
  • New MP feature.  After terminal mode you have to reboot.  Click the button at the top left of the terminal screen
DIY Robocars via Twitter
Practice virtual race this Saturday; the real thing will be on Oct 3 https://www.meetup.com/DIYRobocars/
Wednesday
Wednesday
Derrick Davies liked lisa TDrones's profile
Wednesday
Monday
RT @SahikaGenc: AWS DeepRacer & Hot Wheels Track https://youtu.be/4H0Ei07RdR4 via @YouTube
Sep 14
Sep 8
RT @davsca1: We are releasing the code of our Fisher Information Field, the first dedicated map for perception-aware planning that is >10x…
Sep 8
RT @SmallpixelCar: How this works: 1)object detection to find cones in single camera image, 30 frames/sec on @NVIDIAEmbedded Xavier. 2)comp…
Sep 8
RT @SmallpixelCar: Use two color cones to guide the robocar. No map needed, on onsite training needed. Just place the cones and it will fol…
Sep 7
Sep 7
RT @roboton_io: Great to see http://roboton.io running at 60fps on the cheapest #chromebook we could find! #edtech #robotics #educat…
Sep 3
RT @openmvcam: Crazy in-depth article about using the OpenMV Cam for Astrophotography: https://github.com/frank26080115/OpemMV-Astrophotography-Gear https://t.co/BPoK9QDEwS
Sep 3
RT @openmvcam: Hi folks, it's finally here! Our first draft of our Arduino Interface Library is out! It works over SoftwareSerial, Hardware…
Sep 3
RT @chr1sa: Please let them have an open API. This would be perfect for @DIYRobocars races https://twitter.com/NintendoAmerica/status/1301513099707658246
Sep 3
RT @SmallpixelCar: Lanenet pretty much used all my GPU power on @NVIDIAEmbedded Xavier since I optimized with tensorRT. I need to run anoth…
Sep 3
RT @LyftLevel5: Our @kaggle competition on Motion Prediction for Autonomous Vehicles is now live! Experiment with the largest-ever self-dri…
Aug 24
