cold weather planes
Hi,I'm looking to build a DIY UAV for cold weather. I'm in Canada & it's cool-cold for at least 5 months of the year.Is anyone else building for colder climates???? I'd love to pick your brains on what works.
  • Yes, we flew a telemaster based platform using a MicroPilot autopilot in -20C weather for a search and rescue exercise 30Km from where we launched. Worked well.
    Greg Lewis
    Greg@aerialinsight.com
    www.aerialinsight.com
    http://www.aerialinsight.com/
  • T3
    temp control using PWM current is a source of noise, be advised.
    thermos around barometric sensor will make it more likely to cause troubles, it will depend more on windgusts when its own temperature wil vary more from the actual air temperature. pressure sensors are better left equalized with airtemp.
  • Hi
    if you build the fuselage from foam like a thermos can jacket and place all equipment into this insulated space, the waste heat from the equipment should be sufficient to keep it warm enough. At warmer temperatures a sufficiently large ventilation gate should be provided. One could even think about to incorporate a primitive temp. control through a bimetal element.
    W.
  • T3
    NiCd bats have wider temprange than NiMh, but come with memory effect and other surprises. Still, they are down to -20C usually.
    LiPos are worse at low temp but as they heat themselves better (being used for propulsion), it is sufficient to insulate them thermally. Just try to not boil them in summettime.
  • When I was learning to fly with Firebird Commanders, in the Autumn weather it could get quite cold. The NiMH batteries I was using would die very quickly in cold weather and you'd only get a few minutes usage out of them compared to the usual 15-20 minutes. Surrounding the battery with cotton wool helped but the battery could get quite warm so perhaps that was not the best idea!
  • 100KM
    Ive heard of people heating LiPos with their own power by wrapping a heating element around it and hooking it to the terminals when it gets to cold for them to work.
  • T3
    The main issue is going to be the servos freezing. I flew in Winnipeg in Nov and we only had one instance were a servo did not function although the planes were kept in a heated shed before flights. Contact Greg Lewis at aerialinsight.com he should be able to assist as he is up in that neck of the woods and has done some cold weather flying.
    http://aerialinsight.com/
  • T3
    www.aerialrobotics.eu/flexipilot/flexipilot-weather-en.pdf
    It works, I did some 30 landings in the snow and -20..+5C.
    Not funny experience as hands freeze on the controls.
    Basically for snow operations, better use pusher
    configurations.
    You must also get the plane off the car before takeoff for
    longer (15 mins) because of barometric sensor drifts, unless
    you accept some 10m altitude drift after 15min.
  • Look at his page: http://diydrones.ning.com/profile/MartinMueller
DIY Robocars via Twitter
https://t.co/bzpbxytpsv
14 hours ago
DIY Drones via Twitter
RT @chr1sa: My talk on PX4 and FAA certification is coming up at 1:45 PST today on the PX4 Dev Summit livestream. Includes some cool new st…
Tuesday
RT @seesharp: I'm tuned into the PX4 / Dronecode free live conference. Great stuff. Microsoft AirSim talk in 10 minutes. https://t.co/0zbZ2…
Jul 6
RT @masato_ka: 距離センサを3つとESP32を付けたラジコンカーをDonkeyCarライクにNNで自動走行。3層FC極小モデルをTensorFlow Lite for microcontrollerで動かしてる。機体は借り物でRumiCarって言います。Tenso…
Jul 5
RT @SmallpixelCar: My car was able to go all the way autonomously until the crosswalk. It was only 100 yards from the target. What should b…
Jul 4
Liam left a comment on Agricultural UAVs
"Hi
I'm Liam from T-MOTOR. I would like to reach out to see if there is any possibility for us to work together.
We are a propulsion system manufacturer who offers motors, propellers and ESCs for all kinds of drone applications which vary from secur…"
RT @SmallpixelCar: Smart move. The car used the shadow to guide it through the bridge. This was never in the training samples. But it learn…
RT @SmallpixelCar: Getting closer to the target. Single camera. Untrained road. https://t.co/Wsr7RwDamj
Jun 29
Richard Cox left a comment on Australia
"Anyone in the DIYDRONES Australian subgroup based in Alice Springs, NT?
I am experimenting with Ardupilot (standard Arduplane), Pixhawk 4 FC in a 4-ch
RC "AXN Floater Jet" foamy plane..."
Jun 29
Omar Sykes left a comment on Australia
"Hi everyone, I am looking for someone who is good at drone building, repair and software in Adelaide. Please give me a call on 0477 319 219."
Jun 29
RT @RoboticMasters: #donkeycar https://t.co/czuLoVRcA4
Jun 29
https://t.co/DKQbNTbz0g
Jun 29
RT @RoboticMasters: Donkey car, car car car car car car; Donkey car, car car car car car car; Donkey Car. Anyone like our tiny tiny donkey…
Jun 29
RT @SmallpixelCar: After improving DBSCAN speed, I can get 11 frame per second on @NVIDIAEmbedded Jerson Xavier MAXN mode and the autonomou…
Jun 26
RT @Heavy02011: Join us at next Virtual Race League: ⁦@diyrobocars⁩ Race #4 - Parking Lot Nerds, August 1st https://t.co/5KUpu7VGaH
Jun 25
RT @SmallpixelCar: #CUDA implementation should be easy, because most of the time is on distance calculations berween two points and if the…
Jun 25
