Common power supply to uBlox GPS/Compass?
Based on some advice I've read, I've decided to run shielded CAT 6 cable to my GPS/Compass, which is mounted out on the wing of my Skyhunter.
I'm setting up a Pixhawk and 3DR GPS uBlox LEA-6 with Compass.  Since there's a 6 pin GPS connection and a 4 pin compass connection, I'm 2 wires short in the 8 wire CAT 6.  From what i can tell, both items run off 5V so I was hoping to commonise the power and ground between the compass and GPS.
I checked for continuity of power and ground and it exists at the Pixhwak ports, but power is not connected at the GPS.
Haven't had any luck searching for this specific info and don't want to break anything experimenting.
So my questions:
Firstly, am i wasting my time running shielded cable?
Is it possible to run GPS/Compass power together?
Is there any issues with this setup (will i break anything)?
Cheers,
Dogga
  • Thanks iskess. Appreciate the advice.
  • If they are both 5 volts there is no reason why they can't share power and ground wires. Even if they were different voltages you could share ground. But you really don't need to share anything because GPS only needs 4 wires, not 6. GPS only need +5, Grd, Rx, Tx.
    Shielded cable is a good idea. There is no way to know if you actually needed shielded cable without experimentation, but it certainly eliminates some variables. I remove the heavy outer insulation and heat shrink every 4 inches or so to keep the braided shield from fraying.
DIY Robocars via Twitter
RT @TinkerGen_: "The Tinkergen MARK ($199) is my new favorite starter robocar. It’s got everything — computer vision, deep learning, sensor…
Monday
Monday
RT @roboton_io: Join our FREE Sumo Competition 🤖🏆 👉 https://roboton.io/ranking/vsc2020 #sumo #robot #edtech #competition #games4ed https://t.co/WOx…
Nov 16
DIY Drones via Twitter
First impressions of Tinkergen MARK robocar https://ift.tt/36IeZHc
Nov 16
Our review of the @TinkerGen_ MARK robocar, which is the best on the market right now https://diyrobocars.com/2020/11/15/first-impressions-of-tinkergen-mark-robocar/ https://t.co/ENIlU5SfZ2
Nov 15
RT @Ingmar_Stapel: I have now explained the OpenBot project in great detail on my blog with 12 articles step by step. I hope you enjoy read…
Nov 15
RT @DAVGtech: This is a must attend. Click the link, follow link to read the story, sign up. #chaos2020 #digitalconnection #digitalworld ht…
Nov 15
RT @a1k0n: Got a new chassis for outdoor races (hobbyking Quantum Vandal) but I totally didn't expect that it might cause problems for my g…
Nov 11
First impressions of the Intel OpenBot https://ift.tt/36qkVV4
Nov 10
Nov 9
Excellent use of cardboard instead of 3D printing! https://twitter.com/Ingmar_Stapel/status/1324960595318333441
Nov 7
RT @chr1sa: We've got a record 50 teams competing in this month's @DIYRobocars @donkey_car virtual AI car race. Starting today at 10:00am…
Nov 7
Nov 6
RT @a1k0n: Car's view, using a fisheye camera. The ceiling light tracking algorithm gave me some ideas to improve ConeSLAM, and having grou…
Nov 5
RT @a1k0n: To get ground truth I measured the rug, found the pixel coordinates of its corners, calibrated my phone camera with my standard…
Nov 5
RT @a1k0n: @DIYRobocars is back in December, but outside. Time to reinvestigate ConeSLAM! I rigged up a quick and dirty ground-truth captur…
Nov 5
