I have the 3DR 915MHz telemetry set which came pre-assembled.
The BAUD rate is 57600 and all of the settings are the same on both radios.
Whenever I try to connect however I get "Connect Failed"and this message under details:
Has anybody gotten it before? How can I fix it?
i had the same issue...
after inspecting the board i noticed a tx line was damaged...
Replaced the one module... issue fixed.
