Hello guys,
when i turn on my Arducopter doesn't stop to make constant sounds. Why can it be? Maybe a bad connection?
Thanks!
You'll really have to try and give a better description of the problem.  From what you give us it could be anything.  What sounds ?  beeps ?  Do they come from the motors ?  Did you calibrate esc's ?
Yes, they are beeps and come from the motors. Yes, i calibrate them. I have made every step of the tutorial.
This Beeps mean, that the ESCs have no signal from the board.
Plugged in the wrong way?
They were plugged when i bought it.  I have checked them ant they are rights
mine did this until I calbrated the radio with mp.
Yes, i did the calibration with Mission Planner. I am using a RC with only two channels.
You can´t fly a copter with only two channels
Yes, obviously. First, i want to test that everything works well and then i will buy the RC to fly.
I think this will not work. The APM needs the signals of 4 channels to calculate the motor speeds.
So, do you think that for this reason the Arducopter makes beeps?
I don´t know. I never tried to to start an incomplete copter.
But i hope so. A copter with missing channels is not flyable and dangerous.
