Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Sad to see APM dropped.
First rc1 flight behind and quad still in one piece. No errors in the log. I'm seeing quite a lot altitude surfing which is visible in log too. Also baro and gps altitudes are not in par. Barometer seems to show higher alt than it actually was. I did autotune in around 4 meters and raised during it meter or two because of surfing. Baro shows 8 meters :|.
Tested autotune, result wasn't best possible. Quad is barely flyable and has quite strong wobble if sharp commands are given. Earlier version did rock solid settings.
PIDs, earlier and now:
stab 8.5, 6.2
RLL
P 0.26, 0.13
I 0.26, 0.32
D 0.018, 0.002
IMAX 500, 50
PIT
P 0.35, 0.08
I 0.35, 0.21
D 0.02, 0.002
IMAX 500, 50
New yaw values seemed to work fine.
http://www.droneshare.com/mission/83882
Thank's Randy, no Pixhawk for the moment but in wish list for this year :) :I think I find an issue in land mode but I have to do another check and post in the correct post (3.2.1) during next week with logs.
Great to see this, Randy. We, like everyone else, are now firmly in the 32-bit era, so it was time to take advantage of that power and leave 8-bit (APM 2.6) behind for new development.
That said, the Copter 3.2 code, which runs great on APM 2.6, will continue to be available forever and will be supported (critical bug fixes, if needed) for a long time.  So for all of you with APM 2.6, no need to fear. Your copters will fly great and the mobile/desktop/cloud apps that work with them will continue to improve, bringing new functionality outside of the autopilot itself.
Is it still possible to use DCM? I don't have much faith in EKF currently given the number of EKF_CHECK errors I still get on a fairly regular basis.
Randy,
Will one of the releases allow remapping channels so that we can utilize different inputs for mode changes.
Joe
Thank's Chris, shure it's time to update harware; we have to give many thank's that we have a high mature code to still enjoy flying with our old APM, mine is only a minor issue but I begin with this only for work (crop monitoring) and now it's a hobby too so follow updates and find issues is part of it :)  .
Oooh, Alexmos support...to do what exactly?
to do what it says in 8 c I would imagine :)...to send demands to it.
So i just maidened ac:3.3 on my Y6. Flew great! Except for one exception, well two really. But the second one is not an ac3.3 issue, just a satellite issue.
First issue: It seems as though every time i plug in my birds I get BAD AHRS errors. This has been happening since 3.2 for me on 4 separate frames and configs.
Second issue: Seems like I was about to have a flyaway when about 3 feet off the ground. I was between my car, and my house, and a big building, so that is to be expected. But i thought EKF would catch that before it happens? It started flying off at about 30 degrees when i hit stabilize and full throttle to get it out of danger. It went about 30 feet horizontal before i hit stabilize.
When is UAV/CAN going to be enabled? I really want to try this zubax that has been sitting on my shelf for 6 months.
Cheers! And thanks for all your hard work and efforts! I appreciate it!
Have you the logs of the second issue?
Just uploaded 3.3 rc1 and reset to default. Followed by a complete setup.
At the moment i have only one error saying something like "EKF Variance" (LED is flashing blue/yellow)
Apart of that it's flying ok so i decided to go in the garage and run AutoTune.
here is the result compared to previous version :
                           AC3.3rc1       Old AC3.2.1
RATE_PIT_P        0.07585344    0.1249999
RATE_PIT_I         0.1896336      0.1249999
RATE_PIT_D        0.004598       0.006499999
RATE_PIT_IMAX   2000             1000
RATE_RLL_P        0.04932502     0.12
RATE_RLL_I         0.1233125       0.12
RATE_RLL_D        0.00255887     0.006999999
RATE_RLL_IMAX   2000              1000
RATE_YAW_D      0                    0.004
RATE_YAW_I        0.04019607    0.04
RATE_YAW_P      0.4019607       0.4
STB_PIT_P          10.82979         10.59375
STB_RLL_P         7.311701          10.94531
STB_YAW_P        4.477529         6
