Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Loaded 3.3 today, previous 3.2.1 flies fine in PosHold but with 3.3 I got error (Flightmode err 16) and PosHold is not working
Loaded 3.2.1 back and it is rock solid in Poshold.
I did not change anything between the 2 versions
Did this (Note #1: because of the accelerometer range change (see 6b below) this upgrade will require the vehicle's accelerometer calibration to be done again.)
Log from 3.3 attached 2015-04-13 19-18-15.log
Log from 3.2.1 attached 2015-04-13 18-38-21.log
Logs zipped
Ok, so Tridge has tested the Zubax GPS and it "works nicely!" it seems so feel free to give it a try and report back!
Thanks Randy. My 4 Year old Daughter is into everything. Have had to lapse a little with playing the devs builds in the park. Have a pix and am looking on adding a second GPS. Maybe the Neo 7 as a redundant backup? Humm..
Great, thanks for the info :-)
wow - thank you very much to all the developers!
Or
Thanks for the tip. I changed aggr to 0.1 and did another autotune. Now pitch seems ok, but roll is still quite bad. Lot's of wobble and quite sluggish. Yaw feels quite aggressive but it works. Oh, when in stab mode and doing yaw, copter gained quite a lot altitude. This didn't happen in althold mode.
new results:
stab roll & pitch: 6.25, 10.95
rate roll
0.08
0.21
0.002
500
rate pitch
0.26
0.63
0.012
500
yaw
0.65
0.065
0
100
Strangely lot difference in roll and pitch?
log: http://www.droneshare.com/mission/84513
pic of the quad: http://imgur.com/USASeBr
It's 700mm.
Pomaroli,
Aha, I had forgotten that there's a new CLI_ENABLE parameter that allows enabling/disabling the CLI and in AC3.3 it defaults to zero. Set it to "1" and the CLI is enabled again.
This was done because we found that having the CLI enabled could cause problems for scripts or companion computers talking to the pixhawk as it rebooted. We could default the parameter to "1" but when Tridge and I discussed this we thought that most people were moving away from using the CLI anyway. As far as we know, there are no features in the CLI that can't be accessed through mavlink.
Simple test flight with autotune on Y6B - tuned parameters are not usable - reverted to manually tuned.
What is changed by Autotune_aggr and Autotune_Axes? What are recommended values?
Hi Kuisma,
Yeh, roll is still messed up. The good news is your problem is specifically what the latest changes to autotune are designed to fix. (Rate noise during the test)
To dampen down your Yaw control I would suggest turning on feed forward and using your acceleration parameters. A good starting point is:
ATC_ACCEL_P_MAX,110000
ATC_ACCEL_R_MAX,110000
ATC_ACCEL_Y_MAX,36000
ATC_RATE_FF_ENAB,1
If the FF is set to 1 then Autotune will set them at the maximum your copter can handle.
Hi Hubertus,
In exactly what way is it un usable?
Autotune_aggr is a parameter that sort of defines the noise rejection of the autotune. It should have been 0.1. Autotune_Axes is a bit mask to define what axis will be tuned. 1 is Roll, 2 is Pitch, 4 is Yaw, 3 is Roll and Ptich ect ect.
You have the same a similar problem I am seeing with others (but not enough to stop you getting what looks like a reasonable tune) and I hope the next release will fix this.
