Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Leonard, this was something i was not knowing. Activating ATC and FF will be considered during autotune and set to max the copter can handle ? if it's so this is pretty cool!
As i'm flying almost acro i haven't enabled ATC and FF but considered the benfits i'll give it a try....
Leonardt,
tried again flying with the autotune parameters - it´s flyable, but there is some overshoot and oscillations in roll. Rate P/I pitch is out of range according to MP - is this a problem? Response in pitch axis is quite good, so perhaps i should leave it to the tuned params.
Randy you're right, what i used it for is in the Mission Planner in the Register "Terminal" to download the logs to my computer (usb) or to enter Setup for reset.
Starting from 3.3 after connecting to pixhawk a message "Port already open" was shown.
I'll try it out if its better by setting CLI enabled..
Nice to Know Chris your continued support for the APM 2.6. I have been very pleased with the performance one my TBS quadcopter using AC3.2.1, no issues perfectly works well with sunnysky 800kv motors and my flashed 600hz esc Simon K. It bring the 8bit apm to life, even in gusty wind i still enjoy the ease of flight. I shall take the step towards pixhawk, just a couple of more moths till the firmware is well tested.
And congratulations on the 3DR Solo, amazing drone, seen your videos. Solo name suits it perfectly i would say, single pilot for camera and drone. No need for for second operator or second remote. GREAT WORK!!!!!
Hi Hubertus,
Oscillations is definitely bad. But it is strange as tuned pids seem to be more conservative than your original pids.
If you could try the autotune in the next release for me I would really appreciate it!!
Perfect, what are the parameter changes needed?
RB
Cool, Thanks Pomaroli!!
I will be very interested to hear your feedback!!
With the next autotune, I hope you will get a nice tune and close to maximum acceleration parameters.
"support do-set-home command (allows return-to-me and locked home position once GCS enhancements are completed)"
Can somebody provide some information on this specific feature above (10.a)? Is this implemented and its currently usable? If not, then when will it be available?
Evan
I connected my Zubax GPS, LEDs on the zubax are lit but I get no GPS signal through to the Pixhawk or indication in APM Planner.  I can't find anything in the parameter list that looks like a UAVCAN parameter or to direct gps signal.
Hi! How many minutes does autotune require to complete the entire cycle? I am having a hard time doing so since my flight time is just 7-8 minutes with my current setup.. I always end up landing the quad due to low voltage...
Hi Erwin,
I am glad you asked :)
AUTOTUNE_AXES controls which axis is tuned.
1 is roll
2 is pitch
4 is yaw
So then you add them if you want to do multiple axis so
3 is roll and pitch
7 is roll, pitch and yaw.
So do one axis then put a new battery in and do the next axis.
Let us know how you go.
Leonard
Hi
Yesterday I installed AC 3.3 rc1 and today I ran Autotune. The result is not good, there is some overshoot, the yaw jumps.. Adds a log of my flight
best regards
