Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Tags:
Here is the log. I'll do another try on Wednesday when it should be less wind here and of course I can do another test when the next RC is out.
Changed droneshare settings. Maybe now? I did change back. Btw, why p limit in mp is 0.2? 0.35 on mine seems to be ok..?
I restarted the Autotune since the quad descended really low the first two times and I didn't remember it doing that on the previous version.
Is there any more information on what changed to reduce the CPU load so drastically?
Hi Kuisma,
Rate D is limited at the lower end to 0.002.
I think I see the problem.... maybe.... It looks like the release went out with AUTOTUNE_AGGR set to 0.05. This tends to be a little sensitive, the default should be 0.1.
Thanks!!!
Hi Maciej,
The release went out with AUTOTUNE_AGGR set to 0.05. This tends to be a little sensitive, the default should be 0.1.
I suspect we will get a lot of failed autotunes until the next release candidate because of that default value.
Thanks!!
It would be really useful to be able to tell autotune what size the drone is and what application it is used for and tune accordingly. I have an 800 and the 3.2 tune makes it far too twitchy for video work.
I noticed an immediate improvement on my newly built quad. It takes off much more nicely and descent is smoother. No Auto Tune done yet, but just did one yesterday with 3.2.1. Based on comments I think I'll wait.
That's my 2 minute observation report :)
Are there any plans in the future for Altitude Verification/Input using LidarLITE?
I tested 3.3 today with a early model lidar-lite attached using the PWM interface, following the wiki instructions.
It appears to work hand-held (sonar alt makes sense while disarmed.) However, I had rapid, short climbs when switching into alt hold or pos hold.
My quad is a bit heavy for it's size, 400 class, 8" props, 1.8kg but flies fine on 3.2.1. Winds were light and variable.
Here's the flight with Lidar-light active. Here's one without.
Also, I'll add to the report that Pos hold is not showing up as a valid mode, but only with the lidar active.
APM Planner won't calibrate accelerometers after 3.3
I screwed up and started a discussion instead of a reply so copied to this discussion
I am pretty sure this was caused by the 3.3 upgrade. I have successfully calibrated the accelerometers many time recently and when I tried after 3.3 it times out and will not calibrate. I hooked up my trusty Iris after several attempts on my 550 and the Iris responded as normal. I then hooked up a spare pixhawk and uploaded 3.3, attempted a calibration with no results. Neither unit will calibrate now even if I revert back to 3.2.1. I took the 550 to School today and successfully calibrated 3.3 with a PC running Mission Planner. I came home this afternoon and uploaded 3.3 to my Iris and it now has joined the other two in the calibration fail pile. I am now out of tricks and could use some help.
RB
45 members
1472 members
282 members
470 members
57 members
Powered by
