Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • hi all. please help.
    i just build new quad 250 pixhawk and tx gx7 JR, i can fly good with mode stabilze but i can't control and take off or control with alt hold mode. because the mode alt hold only work with thorttle, picth and roll and yaw not working.
    can someone help me fix this ?
    • Better if you can share
      • a log, easier to help
  • I'm using copter v3.3.3 on a tricopter as shown in the diagram below. My yaw servo is plugged into a Pixhawk main out 7.
    I don't seem to have any control of the yaw servo when the safety switch is armed or when the tricopter is armed. Should I expect the transmitter yaw stick to control this servo on the tail motor? Are there any settings I may have missed to select a tricopter other than when downloading the firmware?
    Thank you...
    3702252294?profile=original
    • as Hubertus mentioned only FC controls that servos, try raising throttle to about 20% aand you'll be able to.
      also, there are a few settings to set for proper yaw control on a tricopter, otherwise it will be "laggy".
      ATC_RAT_YAW_FILT = 20
      ATC_SLEW_YAW = 18000
      ATC_Y_MAX = 100000
      these are for ac3.4, so to find them in ac3.3 just omit the "ATC" part.
      if you encounter "wagging tail" try lowering yaw_stab and yaw PIDs. D needs to be 0 for the "manual like" yaw control, otherwise AC controls yaw too much and it gets slow...
      • Ok, thank you for the suggestions guys. I forgot to mention that I have a 5v regulator plugged into Pixhawk main out 8 and the motors 1, 2, and 4 are opto ESCs that all work fine. The yaw servo seems to be energized but I wasn't sure about the APM operation. Based upon your suggestions, it may be the laggy feel I am experiencing.
        This is my first tricopter, which is also a tilt wing, called a CL-84 from Hobby King. I flew it fine using SimonK ESCs and the stock controller allowed for yaw stick to move the yaw servo. While I wait for Tridge to make some special tilt rotor code for the CL-84 transition servo, I thought it would be cool to try Arducopter v3.3.3 and have it hover in place like a real autonomous vehicle. We'll see what happens...
        • You guys were correct. I re-tested and I do have yaw control, but it is real sluggish. I found the RATE_YAW_FILT parameter and changed it from 5 to 20. However, the other two parameters elude me. Could the names be different in v3.3.3?
          RAT_YAW_FILT = 20
          SLEW_YAW = 18000
          Y_MAX = 100000
          • try searching for "slew" and something related to acceleration over Y axes.
            setting those will give you the "manual" like yaw control.
            also, it helps to properly set servo endpoints to something like 1100-1900, defaults are really minimal.
            do not forget your servo midpoint, i find that setting it slightly off center to counter natural yaw helps, but since it is a "plane" not sure how it will affect the fixed wing mode.
            • That's much better. I found the params in v3.3.3 as follows and set them to your values. I have yaw control now. Thanks for the tips!
              RATE_YAW_FILT = 20
              ATC_ACCEL_Y_MAX = 100000
              • My CL-84 VTOL is hovering quite nicely in some wind now after adjusting some PIDs. This was just a test while I wait for Tridge to release some new Arduplane code for the CL-84 tiltwing. I also updated my Tarot 680 Pro hexacopter from Copter v3.1.4 to v3.3.3 and after re-calibrating the ACCs and GPS, it flies perfectly!
                3702916111?profile=original
                CL84 with APM Copter Test 2 from Gregory Covey on Vimeo.
DIY Robocars via Twitter
Jun 25
Jun 25
Jun 16
Jun 13
Jun 13
Jun 13
Jun 7
Jun 7
May 28
May 15
May 14
May 13
May 13
May 11
May 8
May 8
