Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Good idea thanks
Rob, I don't know if your fix has been implemented in rc5 or not. I see some code changes in the landing gear code. I tested rc5 this past weekend and the RTL waypoint landing gear deploy still does not work during a mission. If I use a Land waypoint during mission the gear works great. Or if I use RTL or Land Via switch the gear works.
Maybe you are interested in other logs:
Tarot T680Pro with 4010 340KV motors on 6S and 13 inch Props
Autotune_aggr 0,07. Much to sensitive, overall vibs
Autotune_aggr 0,05.Looks nearly good, but needs manual tuning.
The corresponding Yaw with 0,1 looks perfect !
I put some additional logs into the dropbox folder ...
Now I tested 3.3 Autotune with 3 Copters and would day there sould be some more steps avaliable to adopt the basics to do a good autotune.
In my personal case (T960) I am still tinking of an parameter which adopts the rpm lag to the pixhawk before doing autotune.
With autotune 0,06 on T960 there is still a bigger differnce between roll and pitch.
Cheers Gregor
2 years is an eternity when it comes to these things. I think you should count your lucky stars that you GOT 2 years out of them, I know I do and am quite content to keep the ones I still have on 3.1.5. 8 bit with very little storage and even less memory is just not going to handle all the new stuff and the new new stuff coming down the pipes. Even the hawks are starting to be pressed.
Leonardt, is the prop data you referred to is still online? If so, could you please share the link please?
Emin, as others have said, there are stable versions of flight code for copter and plane that you can use.  The reason this project develops quickly is because there are lots of people writing code and lots of people testing.
We will never stop developing and never stop testing.
We have said it a thousand times, if you are not actively testing a new feature then please use the stable versions.
Thank you!
Thanks for the report Nick and thanks for including enough detail to make it very helpful
Nick (and others) something to keep in mind is that using RTL as a bailout option for a climbing flyaway is not a good option because it relies on the altitude controller to maintain altitude and the reason the vehicle is climbing in the first place is because the controller is already messed up.  Stabilize is best but there are cases where Loiter can be an option (in cases where the vehicle is going up and not away)
Devs
Is there any consideration for adding the option to ignore the internal compass if you have an external? Redundancy is nice but if the internal is too effected by EMI despite all best efforts perhaps this would be a better alternative to high offsets / mismatch between the internal and external causing it's own set of problems. Thank you devs for your work!
"DYS Marcia" 3-axis gimbal for GoPro 4 (with some hardware and software mods) and "APM:Copter V3.3 RC5"...
Interested in answer too, I'm not have a Pix yet but I'm worried what happens with int compass if I had to solve my compass problem with an ext one and them change my APM for a pixhawk? the problem migth appears again?
Thank's for all new devs, I following near to pick then when I change my boards :)
I need some assistance.  Trying to recall if there is another way to connect a 2nd GPS using +5V, GND, RX, and TX on the Pixhawk.  I damaged beyond repair the Serial 4/5 port and would like to use the Aux Output rail to setup a second GPS.  Is it possible, if so what pinout would work for this and configuration parameters?  I currently have LiDAR on port 5&6.
