Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Perhaps vibrations affect a connection?
went back to 3.2 seems fine. I highly suspect it's APM2... guess I'll post over there and see if Bill has any idea's.
I had the same problem with APM2.  Just reload with the latest beta APM Planner and it should work fine.  It is an APM planner issue that has been addressed.
RB
Richard, you installed AC 3.3 rc5 on APM 2?
I was thinking that the highest compatible version of AC for APM 2.x is AC 3.2.1
We are referring to APM Planner 2.  Mac OS GCS
Checked it just now. I remembered that incident as soon as I started reading it.
So it is still flying!..:)
I got you now but it really doesn't seem like it in the text...
Excellent thank you I will try that.
Yes your right that corrected that. Great!! Thanks...
But..... my teensy lua script no longer works. Bummer.... very handy. No GCS needed. Not sure where to look to address that problem. I did set the  SERIAL2_PROTOCOL to "3" as suggested. The X8R receiver is getting telemetry just no data from the pixhawk it seems.
Now if I get DCM bad heading I won't know... sweet!! Fixed!! LOL
Should have said APM P2 sorry my mistake.
Hi UAS_Pilot,
I can confirm looking at the logs that the autopilot wasn't running when you crashed. It looks like you lost power to the pixhawk.
Sorry about your crash!!
Hi Gregmaan,
I would encourage you to set these parameters
MOT_THST_BAT_MAX,25.2
MOT_THST_BAT_MIN,21
MOT_THST_EXPO,0.8
MOT_THST_MAX,0.95
These are the parameters that linearise the lift of your props and ensure your tune stays right as your battery goes flat and as you increase and decrease your throttle.
I will need more logs of your autotune on roll and pitch before I can help you further. I can tell you that you don't expect your roll and pitch pids to be the same on a hex though.
