Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
3DR owns trademark "Pixhawk".
I wouldn't really trust all the manufacturers... especially those one selling the latest and greatest at half the price.  btw, show us the log...
Nonsense. There are plenty of clones around, most of them are fine. I got stuck to avau clone as it is the tinies one and works just fine. Most issues got nothing to do with FC, it is all about power supplies, filtering, connectors, wires, etc.
The log is attached to my message at the start of this chain. Cheers
This was a bug in MP 1.3.29 and is fixed in 1.3.30. I spotted it too and reported it in the MP thread on here and it was picked up by Michael Obourne and sorted quickly.
What's better, a manufacturer in China using cheap labor and Chinese parts or a manufacturer in Mexico using cheap labor and Chinese parts? Pretty much "six of one or half a dozen of the other"
They are all using the same Schematics and pretty much the same BOMs.
The reason 3DR sells for twice as much is not because it costs them any more to produce than a China plant but because they actually invest some in both customer support and help support ETH Zurich. But I find it hard to yank twice as much of my hard earned cash out of my wallet to buy a Hawk simply because it says 3DR on it.
I'd say 3DR is selling older hardware at twice as much as everyone else.
I would like to remind everyone that this is just a release candidate, not a full release. This is where we ask the wider community to give us feedback so we can address problems and bugs before we do a release.
So if you are flying a release candidate then you should not expect perfection. You should also not base your decision to return hardware based on release candidate warnings.
The Ekf is relatively new and we are still polishing it. Too many people are getting too many warnings for my liking and we don't have clear solutions to these warnings.
Please be patient as the devs are under a lot of pressure at the moment.
I would also like to apologise for the slow reply to some of you. I have been away for work and have not had time to reply as I am limited to my phone. I will be back on line in another 5 hours or so.
Paul, Atheron, the log you posted does not contain signs of IMU2 malfunction. it is pretty easy to see actually. When graphing IMU2 ACC x,y,z on an affected clones, all three show solid lines stuck at different and mostly unreal figures, showing accelerations in the magnitude of 20-60 G.
Artem,
The only reason you don't see IMU2 issues in this log is that I shorted the power connector before connecting the battery (as per your previous suggestion - gratefully received). Before I did this (even with this new FC) I was getting IMU2 issues, so they are still there even on this new 2.4.6 hardware spec. The issue reported in this thread are more specifically aimed at EKF Variance. I get it every time I arm my FC. Same with my old one!
What is the default setting and wich to choose for Tarot FY690S ?
Any help on this are welcome ;-)
I'm still flying 3.2 and after careful set up and calibration have zero error messages and it flies flawlessly. Perhaps if others simply want to fly without testing might want to just use 3.2 for now.
I agree and I am flying with 3.2.1.  It is great!  EKF seems to work ok for me on this release.
I just thought it was worth mentioning so that the Dev's and testers were aware and offered my info in the hope of helping with information.
As far as I can see it is probably unlikely to be a hardware issue as I have three different genuine 3DR PH's all doing exactly the same thing.  I am not trying to complain and fully accept that 3.3 is still beta.  I just thought is better to report a possible issue than waiting and possibly finding it later!
I have found that the support and info from both 3DR,, all of the code warriors here and the DIY community to be fantastic.  Although I am still not quite sure what the actual problem is.(I don't know if anyone does)  I have a 3DR support ticket in and will let everyone know what I find out.  Obviously it does not affect everyone and 3.2.1 is still great.
I have and I am still trying to work it out myself (with my limited knowledge) but please do not think that I am having a go at anyone.  Just trying to share in the hope of helping by supplying information.
@ leonard
I agree with them
