Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Artem, Sorry, I know this is a little off-topic for this post, but I saw mention in another post from you about a possible resolution to the IMU2 Vcc issue - something about soldering a 10k resistor to the pixhawk board. Could you possibly send me details of this mod? Thanks, Paul
http://diydrones.com/forum/topics/pixhawk-bad-accel-health-apm-3-2-...
talks about the resistor and the reason. This has been going on since December
Leonard, I totally understand what you are saying here. I am very grateful, as we all are for the efforts of all the devs on this project - you provide an awesome service to all us enthusiasts, and we wouldn't be able to practise our hobby/profession(in some cases) without the awesome efforts you selflessly provide. I also appreciate the situation with beta code - I just raised the post here purely to ascertain if my issue was down to my own hardware setup or if it was something code related. As regards returning hardware - I wasn't considering doing this because of the EKF issues, but for the IMU2 Vcc filtering issue which is purely hardware related (just bought a second HK copy based on pixhawk and this also has the Vcc issue causing bad accel/mag health reports unless I first short the power cables before connecting battery).
Can I ask though - in order to take 3.3 and switch off EKF, returning it to the filtering methods of 3.2.1 - is it simply a case of setting EKF_CHECK_THRESH to zero?
Are there some modifications around for this "IMU2 Vcc filtering issue" to be solved?
Can someone direct me to the schematic and point me to the problem area?
Thanks!
Hi Paul,
No problems and thanks for the kind words.
I am sorry but I am not sure if that would turn the EKF off.
Don't worry Alex,
I don't think anybody is complaining. All I am saying is this code is still a work in progress.
The Devs rely on all the feedback people are giving here to make sure the eventual release is as good as we can make it.
I just don't want people to get too stressed if they see a problem they didn't see with 3.2.1.
If you look about 7 posts up, Craig answered this with the following:
The article basically suggests the simplest workaround being to connect a 4k7 resistor on the back of the  power module between the 5v vdd output and ground. I will maybe try this when I have the chance to pull my hexa apart (power module is a bit buried on my hexa!)
Hi Henri,
Sorry for the slow reply. I have tried a couple times but couldn't do it as I only had my phone.
This is the process I use when starting tuning a large copter. First up set these parameters
MOT_THST_BAT_MAX,number of cells x 4.2
MOT_THST_BAT_MIN, number of cells x 3.5
MOT_THST_EXPO,0.75
and
THR_MID,300
Then set the control loop parameters to their defaults.
In stabilize slowly increase your throttle until the copter starts to lift of the ground. Listen for any sign of oscillation and if you hear it be ready to shut down the throttle immediately.
One of the things I find is if you are hovering lower than 30% then you will tend to have trouble with autotune. If you are hovering at a very low throttle position then add weight to get your copter up into the 30% to 40% range. If you are above that then no problems.
Once you can take off safely then you can start testing small roll and pitch inputs. Keep the copter low so you don't do too much damage if you need to shut it down. I will tend to do this at around 0.5 m.
If you find the copter reasonably safe then you can increase height to say 5m and increase the roll and pitch inputs.
If you find the copter is a little wobbly (slow wobbles about as fast as you can say wobble wobble wobble) then increase the Rate D terms (you can use the slider set to go from 0.004 to 0.008). Just make sure you don't increase it to the point you get oscillations.
If you get oscillations then you may have a flexible frame or something like a gimbal that can move. If you are lucky you will be able to just reduce Rate D. I haven't seen anything that oscillates on the stock PID settings.
This should get you flying. Then you can build up your roll and pitch inputs (30 degrees) to the point where you feel comfortable running auto tune. If you don't feel comfortable you may need to do a manual tune before you can run Autotune.
Hope that helps and sorry for the delay!!!!
I just took 3.5rc out and did some flying. Overall, works great, except that when I launch in Stabilize and switch to Alt Hold, the copter drops fast toward the ground until I throttle up. It's recoverable, but it falls fast enough to potentially break an arm. After I've done it once, switching between Stabilize and Alt Hold (really, any altitude-assisted mode) it doesn't do it. Is that just a parameter adjustment I need to do? I would say it is, except that this weird drop only happens once between arming/disarming.
hmm, it does not happen to me. it sometimes drops down from alt hold into stabilize if you did not have throttle leveled up to where it needs to be, but I just flew in both alt hold, loter, stabilize - did not drop down once.
Sounds like you need to adjust your THR_MID value. You set this so that in stabilise mode you get a hover with your throttle in mid position, then when you switch to an assisted mode the same mid position holds the altitude.
Guys. I really need help...
I'm really struggling to understand a recent problem my hexa developed. It has been flying with no problems until yesterday.
It developed a sudden lean to front/right and I cannot understand what the problem is. You can see the problem around the 3 min mark on the log. Plotting channel 5 vs channel 6 shows you the problem.
It was running 3.2.1 beautifully and in last resort I installed 3.3 rc5, made a full default restore and started fresh. Unfortunately it did not solve it..
I need some guidance please.
Thank you
