Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Aha! I figured it was something like that. I will go plug the tricopter in and see what that does. Thanks!
Strange, I didn't even have the tricopter yet in April, and I flashed the latest version sometime in early June and that was the version that worked.
Roger, figured that's what you meant.
It was actually 0 and 1 until randy changed it, which made more sense from the name of the parameter YAW_SV_REV(erse)  "true" 1, "false" 0, i missed the later commit where he did -1 and 1.
or RC out -1/1 depending on conditions.
Yeah i actually do all the reversing of channels in my radio, i never touch the flight controller.
nope, talking about different thing. full parameters list -> RC7 output ->rev -> -1/1
been flying tricopters with AC code long enough to tell it works very good, the only thing which didn't ever work for me properly is autotune. it worked OK up to 3.1.5, later revisions changed it to absolutely useless. tried on RCE and my own 6s powered tri.
That's fine if the quad is moving the wrong way relative to your sticks, but for anything gyro-based that won't work since the signal originates from the FC and not the radio.
I'm not seeing any of those parameters in my list.
Likewise. I don't know what's going on all of a sudden. Like I said before, if I flash 3.2.1 on this thing, it works fine. Just confirmed that this morning after posting my logs. But if I put 3.3RC7 in, whirling death blossom.
Well remember that you have to do rc calibration, so any changes you make in the radio propagate down the line. I for example change the servo limits and pitch direction in my radio, everything is default on the parameters in APM. This lets me swap a radio if need, since nothing changes on the pixhawk, only on the radios (if there is a channel that needs reversing on one radio but not the other).
You might have to do a forced parameter update in Mission Planner.
Ctrl + F and click ParamGen.
