Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Dear Reader
I don't really know where to post this question and if wrongly posted I hope a civilized moderator will transfer it to its correct place. Thank you. Now to my question:
As impressed as most people are by fascinating radio-controlled flying sauces, I am equally surprised over the design capabilities of some individuals. Taking a passed away dog used for hunting many years and making a set of gloves out of its skin in memory of it is one thing, but to turn a dead cat into a drone... Is that ethical?
Frankly, what do you think?
The cat forums are raving about it, so left is to know what the drone community thinks. After all, where is the moral in this if God created us? Shouldn't also a cat deserve a nice funeral the same way as us humans.
This is what I found:
https://www.youtube.com/watch?v=S8QWMatuiWw
/Kalle
People (governments) are using drones to slaughter entire villages, so the cat thing is really nothing..  God and Drones have nothing to do w/ each other.  (I wouldn't do that to my dead pet, but there are all sorts of people in this world!)
(And, this is more of a technical info forum.. Go to rcgroups drone section for random chit-chat)
2+ years ago when we first saw a dude turn his dead cat into a quad most of us were appalled, but it started a whole genra of frames and frame conversions. Whilst I find it in poor taste I don't find it any more odd then someone taking their dead pet to a taxidermist.
Artem,
I think it would be nice if you give us a brief summary of the conversation in english.
As I (maybe false) understood there are two versions of Pixhack, one seems to be good an the other one has the vibes?
Yes, the original CUAV pixhack has aluminum shell and the silicon padding inside was specifically designed to dampen high frequency vibes. The plastic case version appears to be not made as good as the aluminum and the silicon pad is harder and is of the different shape.
I have used the original CUAV pixhack for one of my clients. It is indeed a quality made piece of hardware with great IMU dampening especially effective against high frequency vibes. After a positive experience with the "real" thing I have erroneously purchased one in a plastic case (didn't pay enough attention) that one went right back to the seller for a full refund.
Hello,
Is this negative baro readings are ok in flight?
@Paul
I'm sure you know about these very economical LDO: http://www.linear.com/product/LT1085-Fixed
They are superior in many ways to any switchers and the famous 7805.
They'll give you excellent line (0.015%)  and load (0.1%) regulation.
I like them as they are so economical that you can afford to have one for your M8T or M8N another one for your Pixhawk from a 2S battery. Incredible results.. Anyway some prefer a single noisy switcher reg.
Henri
Igor, yes exist original Pixhack and fake. I use original with aluminium case. But I think original whatever need external anti-vibration platform on big frame.
Artem, у меня точно оригинальный, во-первых в аллюминиевом корпусе и фирменной коробке, во-вторых купленный напрямую от продавца с некоторыми доп. шнурками. Я бы тоже летал на 3.2.1, но мне очень нужны фишки от 3.3, в частности снятие текущих углов с подвеса на Шторм32. Программер сказал, что вырезать этот кусок кода из 3.3 и вставить в 3.2.1 очень трудоемко, приходится пилить 3.3, хотя она конечно мягко говоря сыровата.
Yes, that just means that the baro thinks it's below the home altitude.  The baro suffers from drift (a natural consequence of the type of sensor) so it's possible to see negative numbers even when it's not below the home altitude.
This looks like a very sudden drop, I can't see the logs but I'd guess that it's an aerodynamic effect caused by the vehicle moving.
Dear, thanks for your answer. I have tested the px4 stack, but I prefer the apm:copter ;) All works perfect on it, but the hott protocol will be nice to have for fly without pc radio.
Is there an option to load the hott-module on-the-fly to firmware as example by sd-card?
Or can I add this module to firmware and recompile it simply?
I have some experience with microprocessor programming on C/C++.
Thanks for your time and support.
Thanks for the answer, logs also have disarmed logs. During the flight one prop sliced receiver antenna so i landed for check. But still althold mode altitude drift. My copter still lost altitude but giving more throttle overrides. On previous versions full throttle doesnt any effect and copter lose altitude until it lands.
If you still review the logs its here:
https://www.dropbox.com/s/rxd5rpucu2av5iv/7.BIN?dl=0
Obliviously its not that bad then. Then it would be nice to see a radio controlled parrot designed with some gyro  and counter rotating propellers so it can run on 1 propeller ax from its head.
