Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Probably not helpful, but my radio telemetry works fine on rc8.
It's working on telem1 as well as telem2.
Do you have something else connected in parallel with the telemetry radio with an Y cable?
OOOOoooo~~~~~ right!! that's my fault and no reason to change code to fit my careless.
I am new to arduCopter so when piloting some basic rules are not yet "intrinsic" ;)
Much better IMO would be updating the dataflash log wiki instead (http://copter.ardupilot.com/wiki/common-downloading-and-analyzing-d...), and mention the meaning of sub-error code 15.
Thanks Randy and Thorsten for the info~
Yes the peak was at about 8000-9000rpm from ctrl-F FFT plot but that is due to my 2-blades props I believe. So the motor PRM should be spinning at 4000~4500rpm. At 70~80Hz (4200~4800rpm) the ctrl-F FFT plot also has a peak but much weaker.
Tonight (in UTC+8 timezone) let me post some pictures here to show the setup. Be prepared my setup is going to upset you. Those wiring are so messy!!!
Wilson,
Done, thanks.
Please taka a look at my log's.
https://drive.google.com/file/d/0B6OGol5wOFntSFBKanVkT0ljN1U/view?u...
It's RC7, and since 3.2.1 I have frequent EKF errors....
Is that because of the magnetometers differences (with Gyro/GPS) ?
Recently my copter's turned off motors while in stable at altitude 120m (no logs attached:().
Logs showed that there was EKF nav problem again (error 16 as I remember).
You've said that it's fixed in RC-6/7. I doubt then...
Mark,
I'm going to assume here that you are using telem1 for your radio.
If you connect your telemetry via less than 6 wires, IE, your radio doesn't have or doesn't connect RTS/CTS and if you have BRD_SER1_RTSCTS configured for automatic flow control (2, the default), then you have encountered the bug I reported here: https://github.com/diydrones/ardupilot/issues/2532
This bug was present in the code for older releases, but seemed not to manifest there.
You can work around the bug by setting BRD_SER1_RTSCTS to 0, no flow control.  Please let us know if this is your problem.
I submitted a pull request 3 weeks ago which fixes the bug and also vastly reduces the time required to detect the lack of flow control, but so far the developers do not seem to have had time to review and merge the fix.
--Brad
I realized a very bad autotune with both rc7 and rc8
The frame is deadcat style/V-style. So I started with iris+ parameters as preset. And it was flying ok. Seemed a little agressive.
Tried autotune. Roll tune happened within 2-3 minutes. But pitch took a very long time, more than 10minutes I guess. Yaw also completed quickly. When I look at the tuned parameters, I think roll and yaw parameters are in acceptable range and probably good. But It was so difficult to fly with this new PIDs, I could't test how good they were. With these new pids its pitch was uncontrollable. A screeshot of PIDs after autotune is attached.
COOL~~
Many thanks!!
Randy,
I hope you will see this, I have seen this condition for several times now.
With 2 GPS units, not sure if it is specific for this configuration only, this new algorithm for HDOP value computation sometimes for no obvious reason glitches and it forces HDOP value on the first compass into 0 value. And it remains 0 forever. It is also a problem in the all standard telemetry readers like minimOSD and scripts for taranis to see what factual HDOP is used by the board as by default all scripts only show value from a GPS on a lower serial port. It would be probably better to show in the telemetry values from a currently active GPS unit.
If I unplug and plug power back in - it goes to something reasonable like 0.8 and then works as expected. I have seen it now at least 2-3 times, out of may be a dozen flights, so, it is definitely a repeatable condition.
I also believe it was responsible for very erratic drone`s behavior once where gps 0 on a lower port did not hook up to sats well, had may be 9 sats but with 0 hdop it was chosen over gps unit 1 with 14 sats and HDOP of 0.7.
Thanks Henri, I do see the same figures with my Neo-8M, so reduced the HDOP value to 140 on both birds!
Thanks Andy,
Indeed the value should be lower then the original 230..., so reduced to 140, which doesn't prevent arming, and is allowing me to take off in Loiter.
Did see the fast flashing green indicator as well, so is fine during flight..
Hello Thorsten,
Here are pictures of my copter. 3DR pixhawk sits inside the TBS "fuselage"
Looking from the side pixhawk can be seen. MinimOSD is on the "ceiling", right above the pixhawk. Wires run in-between, touching both pixhawk and minimOSD.
3DR vibration foam is used beneath the pixhawk.
There are this many wires running from bottom pixhawk to the ceiling!
Looking from the copter's back.
Thanks,
Wilson
