Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
The new default is 140, so you should set it to something like that if you are still seeing 230. 230 is now too high for true HDOP, was ok for PDOP. The 140 figure comes from Randy comparing before and after and scaling 230 appropriately, so I don't think anyone really knows if 140 is the "Right" value, but its a lot more right than 230!
Good to know thanks Bill
OK so I think I understand the answer to my primary question about the early "Fence" trigger, and it appears to have been addressed in RC8. According to the release notes for RC8 5b "fence distance calculated from home (was incorrectly calculated from ekf-origin)", which would make sense. I first connect the battery under a shelter about 30-40m from where I ultimately Arm. This would explain the "early trigger".
I have updated to RC8, bit I haven't had an opportunity to test it yet. I have a question already though. When I plugged the copter in indoors it had an HDOP of 1.4 almost immediately, seven satellites, and a 3D Fix. At the same time I get a warning "PreArm: Need 3D Fix". I tend to believe the PreArm warning despite the other indicators. Any idea why I'm getting the extremely fast HDOP value and the 3D Fix check? Is it a mission planner issue relating to the change in HDOP minimum check value?
If anyone has any input on the Pitch oscillation, or the sonar units in the previous post I'd appreciate it.
Nathaniel ~KD2DEY
Nathaniel,
Thanks for testing and for figuring out the Fence issue.  I'm pretty sure you're right.
The low HDOP value is because of the "Note #1" mentioned in the main part of the discussion above.  It's a bug fix to the value pulled from the Ublox (previously it was actually "PDOP").
The "Need 3D Fix" message is clearly a message we need to clarify because someone asked this same question about 2 days ago.  The EKF has a bunch of other tests it does including checking the GPS velocity but we always display the same failure message regardless of which of those checks have failed.  In short, what you're seeing is the EKF isn't yet happy with the info coming out of the GPS.
Thorsten rocks!  All his advice looks good to me.
Some additional info:
  • I think the higher vibes you're seeing on the raw IMU logging is indeed because there's less (or no) filtering on the results you see.  With the lower rate IMU logging you're seeing basically an average of a few readings so very high rate vibes will be invisible.
  • The clip0, clip1, clip2 is not per axis but rather per IMU.  So a Pixhawk1 (and most pixhawk-compatible boards) have 2 IMUs so only clip0 and clip1 will ever be non-zero.  The Pixhawk2 has 3 IMUs but one of those is not vibration isolated so it's really just there to tell you how bad the vibes are on the main board.
  • Hamish may have moved the vibration wiki page or maybe the wiki server has recovered but it's there now.
Randy,
Thanks for the explanation. I understood about Note #1, I wasn't concerned with the number per say, it was really the fact that I got it almost immediately upon powering up while I was indoors! That seems very unlikely.
Any clarification on the units that the sonar values are when reported on the Mission Planner status tab? Or the pitch oscillation I'm seeing when I reach the value of WPNAV_LOIT_SPEED?
Thanks,
Nathaniel ~KD2DEY
Erik Groeneveld : NEO-8M and RC8 lock 18 sat without problem (see the short attached bin file).
Henri
Thanks Randy for your attention and correcting me on clip0/1/2.
Ok so these crazy vibration should be indeed here. A bit confused now where does these high frequency vibration come from. Maybe my non-flex wires are to blame? Or maybe wind blowing into my TBS "fuselage"? can't sure.
At least they don't seem to be from props rotation. My motor should spin at around 140~160Hz (4200~4800)rpm as shown in Thorsten's Raw IMU FFT plot. This also matches to my copter configuration: 480kV motor * 5S LiPo * 3.7volt per cell * 2-blade prop * 45% hovering throttle / (60 sec) = 133Hz. Interesting!! So motor/prop vibration should render themselves at 133~160Hz. It this were to exist the low rate IMU logging should be able to capture this. Am I right?
Is my syndrome common in other logs as well, that bad vibration damping can only be revealed in Raw IMU but not in lower rate IMU log?
Anyway I understand this is the issue of my build and I have to figure them out. Thanks very much Thorsten and Randy for your help~~~
Wilson
By the way, the error Flight-Mode-15 is because you're trying to switch into AutoTune from PosHold flight mode.  You can only enter AutoTune from AltHold.  We could change that, but that's how it is for now anyway.
Hi Wilson,
if I remember correctly the RPM of the main peak reported by Mission Planner was about 8000-9000. Just hit ctrl-F and then FFT to run the analysis.
Bad vibration is detected using the VIBES log at any IMU logging rate. I assume it is based on the 400Hz loop. So no need to enable RAW logging.
I guess we need to see more logs to tell if RAW data is better to check for vibration. VIBES and Clipping seem to work pretty well - although the recommended ranges for Acc and Vibes data is much too high for my setups. The best thing is maybe to look at all the vibration analysis options when setting up a new system.
Can you post a picture of your setup. I also though (for my setups) that vibrations were transmitted through the wires. But other dampers solved it in my case.
Best regards,
Thorsten
FYI - the VIBE message data is based off the raw IMU readings but doesn't require the actually logging of the raw IMU values (as you've noticed).
You haven't said what your PIDs were after autotune, but I had a bad autotune - PID and stabilize values were very low in pitch axis which caused oscillation.  I did two further autotunes with higher aggressiveness values (0.7 and 0.8) and I got much better results.  Also make sure you have MOT_THST_BAT_MAX, MOT_THST_BAT_MIN, MOT_THST_EXPO and MOT_THST_MAX set for your particular setup before you do the autotune.
