Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I've had the same thing, low pitch stab and PID values from rc7/rc8 autotunes.   Your PIDs don't look to bad, you could try increase the stabilize and see if it's better?  Also your IMAX numbers are low, I think these were increased significantly in recent RCs.
it is odd with those GPS HDOP issues as my configuration is precisely same what it always was, same sensors and same bird and all same connections and this condition never existed before rc8.
note - HDOP is set to 0 indeed, but GPS responds with proper changing numbers of satellites from the beginning and this number does not drop or change. I do not see any signs of a GPS restarting there.
Take a look at this log if you have a minute, it is a typical sample of this condition:
https://www.dropbox.com/s/wbtlamaouj3aval/7.BIN?dl=0
Paul,
Actually the GPS messages don't look perfect.  About 20% of messages (i.e. 1 in 4 or 5 messages) are being missed.  Both GPSs experience a single time (8 seconds apart from each other) where there's no messages for 1.0 ~ 1.2 seconds.
You can see it yourself by looking at the "GMS" column.  The values should go up by 200 each time (5hz) but you'll see it's quite often climbing by 400 or even more.
So not sure what's causing this but we should try and fix it.
I have seen quite a few m8n modules drop a LOT of data when set to 5Hz refresh as I have reported before. I had one labeled BeStar that when it was new would drop so bad that mission planner would flash No Fix then 3D over and over. I ran it for a couple of weeks straight and oddly it seemed to go away mostly. The ones I really notice it on are the ones that use a little SMD Ubox chip that is not shielded but even the better ones utilizing the shielded SOC does it from time to time @ 5Hz. When I drop even the poor ones down to 2Hz the data drops go away completely.
https://www.youtube.com/watch?v=3SLgRYYze2g is a video I took before I sat it outside running for a couple of weeks and shows the drops I mentioned.
I agree, but I just do not recall that to be really that bad before, are you sure it is normal?
I just ran bench test of motors at 15 and 20% throttle - see results here, it is X axis from imu1 and imu2.
imu1 shows a reasonable value and slight vibration from the motors running - imu2 is not even sensing anything, it is like one solid white noise.
If it is OK and expected, good to know.
Unless you changed some parameter in the process of flashing back and forth, the problem may still be there as it depends on timing and for me exhibits about half the time on 3.3rc7.  If you post elsewhere, you might want to include a link to the bug report I filed.  It has details about what causes the problem and a pointer to the pull request where it is fixed.
https://github.com/diydrones/ardupilot/issues/2532
It is interesting that more people are reporting problems that seem to be this issue than earlier.  It seems like either more people are testing the release candidates or the timing changed again in rc8 and the issue is even more likely to happen than it was in earlier test releases.
Randy,
If you have any questions or comments on the new code for flow control detection in the PR, I'd love to see comments there.  It has not gotten much attention yet.  I'm sure you guys are extreamly busy trying to get 3.3 finalized!  I did test the code rather completely before I submitted the PR.
--Brad
Craig,
one of my units on this vehicle is 100% shielded in the soldered EMI cage - and that one is having 0 hdop issues, btw, other unit is sitting on the big ground plate on top of the carbon fiber plate covered with copper foil. there should be 0 interference, plus, in the beginning of the log motors are not even running yet, so, there is little if anything to interfere to the level of disrupting GPS feed.
So, what is a proposed solution? use Ublox software and reconfigure all units to 2Hz refresh? Or can we do it from MP software parameters somehow?
I tried to avoid doing any reconfiguration with ublox software as it leads to unpredictable results sometimes making arducopter software to loose any ability to see GPS data at all, I had it once and frankly lost any desire to experiment with what is causing this condition.
Also, if we change refresh from 5Hz to 2Hz - will it affect EKF logic behavior? What is the refresh rate that logic requires to operate, if that even matters?
With all that been said - I presume it is same exact issue GPS units had in 3.2, 3.2.1, 3.3 rc5-7 and only in rc8 I got HDOP=0. It has never, ever, happened before, so, I am quite sure it has something to do with new logic of HDOP value computation.
I have 2 visually similar 3DR radio transmitters - one works fine with any value of BRD_SER1_RTSCTS, other one required CTS/RTS to be soldered in and BRD_SER1_RTSCTS set to ON, otherwise it would not start telemetry feed in 2 power ups out of 5, in average.
With all that done as described it works fine at every startup now. I presumed it was something in the radio and not in the code, but, yes, I had that issue too.
here are more logs, as I tested gimbal outside and got same issue again.
Log 3 has no GPS restarts, all clear and all fine.
https://www.dropbox.com/s/z3zr27tldc2e1t2/3.BIN?dl=0
Log 4 from what I see also has no GPS restarts, I just unplugged power and connected it back.
it showed 0 hdop and had exhibit a classic drunken sailor uncontrollable sideways flying in loiter.
https://www.dropbox.com/s/dye02xv4eyajtiw/4.BIN?dl=0
Log 5 is after reconnecting power immediately after and it shows GPS1 restart in the beginning and a normal flight.
https://www.dropbox.com/s/4dinjmquwgt5nxt/5.BIN?dl=0
there were also flights 1, 2, 6, 7, 8, 9 that did not have HDOP 0 issue. For what it takes it is that sporadic.
In all 3 posted logs I am not sure if I see anything wrong with GMS column values, it is a same value solid line.
APM:Copter V3.3 RC8 in action...
Ve
I don't know any other FC with such high and precise agility. Also the rotations like you do at  Minute 6 were never so nice and smooth as with the latest release. Very nice.
