Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Tags:
@Maciej: just watching the video can't understand if your quad is well tuned, maybe post here your parameters after Autotune.
It seems too soft.
@Shaun, this mistake is due to the inclusion of the variable "Timeus" to CAM messages and restructuring of the message CAM data. Note that the variable "Timeus" has been included in all messages, so the messages ATT and GPS are also affected. To fix this, simply adjust properly "offtsets" in the setup screen Geotag Mission Planner tool.
Your configuration is incorrect, with new releases, for ArduCopter, Mission Planner must be set like this:
I hope I've helped.
Regards from Spain,
Dario
Round 2....
From google drive
Is there a recommended solution for mounting the pixhawk? I notice that leonard recommends effectively hard-mounting it (which I'm not brave enough to do), and I can't find the 3dr recommended foam anywhere else except for 3dr (which I'm not suffering the ordering process and costs for from europe).
I've just bought some of the HK orange foam (about £2 incl delivery here in the UK) which I'm going to use to mount my X2. Will let you know how it goes.
on both vehicles with auav I hard mounted their cases and I find vehicles responsiveness and autotune results to be way more accurate and precise.
inside of the case I use a thin layer of soft foam to wrap corners and secure it in the case to prevent direct contact of the board with plastic case, it seems to work fine.
it gives you more pain to tune and balance motors and props, but, it pays off. foam and platforms on bobbins mask the issue but do not fix it, yet, an original 3dr gel is claimed to be quite good too.
Rate Yaw P 0.86??? And i thought mine was high at 0.7
Problem on optical flow with APM rev 3.3rc8
Dear Friend,
in last week we are testing the APM 3.3rc8 on VR Brain 5.2 , we are checking all nuttx driver and advanced functionality like Optical Flow loiter and lidar terrain following functionality.
So about the lidar we are very happy ... did a lot of test and all work fine as you can see in this video:
45 members
1472 members
282 members
470 members
57 members
Powered by
