Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
It's a guess but I'd expect the two radios to have different settings for the RTS CTS checkbox.  Above is a screen shot of one of my 3DR radios and I'm surprised to find that it's unchecked.
@Brad, I'll review that PR (or maybe Tridge will).  As you guessed, it's just a matter of time and I've been concentrating on trying to get the EKF and it's vibration resistance sorted out with Paul.
Randy, did you have a chance to look at those 3 logs I posted? They have no GMS value issues.
Not to mention you're running a REALLY old SiK version. 1.9 is the latest from Tridge.
Hi Guys! I am making a crosspost to gather as much information as possible. I do not have a teensy yet but according to the APM Copter wiki it is not necessary anymore if I´m using a Pixhawk and Copter 3.3 RC8. I would only need the FrSky FUL1 and a diode.
I was wondering if this is true and if I can use lua scripts found on the web in that case.
Thanks a lot
Paul,
Tridge, Michael DuBreuil and I had a look at the 3.bin and 7.bin logs and all show missing GPS messages.  So we think the cause of the missing messages is just that the SD card in that Pixhawk can't keep up with the 400hz IMU logging.  about 20%~30% of all messages are missing.
Maybe you could reduce the IMU logging down to 50hz and do another flight so we can confirm the GPS rate is coming out reliably at 5hz?
The HDOP coming out as zero is a bit annoying, it means the config messages at startup are not getting through to the GPS.  We likely won't be able to fix this for AC3.3 unless a lot of people start suffering from this problem.  An alternative is to get the default config for the GPS fixed.
I guess you're using one M8 and another lower version Ublox (i.e. Ver6 or Ver7)?  The logic for deciding which GPS to use is based on the number of sats (not the hdop) so if you're using an M8 which naturally has a higher used sat count, it's almost guaranteed to use the M8 over the 6 or 7.
ok, thanks for the response. not sure if you looked at file 4 I posted there - that one had 0 hdop...
both GPS units are same m8n, but a different kind of chips is used, so one with hdop 0 usually has less satellites.
again, an issue that I have had repeatedly was related to very erratic behavior of the drone when HDOP=0 is showing.
What exact mask I need to use for logging to switch for 50hz?
Thank you both for the reply's.
      I'm going to forge ahead and keep messing with the ATC_ACCEL and Throttle acceleration controller P gain Parameters to minimize the Z movements further. Tuning for >10X optical zoom lenses are a pain.
Paul, for logging set the LOG_BITMASK so that IMU is checked but FAST_IMU and RAW_IMU are not.
Can you explain please? As I can see via IMU/IMU2 vibration is acceptable.
Evgeny,
you should look at the Vibes messages (see: http://copter.ardupilot.com/wiki/common-measuring-vibration/ for more details).
As Rob mentioned the vibes are "extremely, extremely high" on your copter - they go up to 120. Normally it should be below 30. Below 50 should be ok. Depending on the damping system, the balancing of the props, and the frame setup it is possible to get the values below 10 even for larger copters (for in Loiter the vibes on one of my copters are < 5).
I suggest to change the damping system and to carefully balance the props/motors.
Hi, I'm looking at the new vibes in an rc8 flight.  X and Y look pretty good but the Z is really high.  All the other vibes I've seen posted Z look roughly the same as X and Y.  Any idea why this might be the case?  I'm using cheapie 14" props (vaguely balanced) on a tarot 650sport quad, with a pixhawk mounted on two plates separated by rubber balls.  I'm not seeing any clipping and it seems to fly fine.
The vibration on the Z axis is generally higher. However, that's indeed a huge difference.
Balancing the props helps as does experimenting with another damping setup.
