Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Round 2....
Sure here are the parameters. It feels much better than the previous autotunes where the quad was very "wobbly" and did overshoot quite a lot.
From google drive
Is there a recommended solution for mounting the pixhawk?  I notice that leonard recommends effectively hard-mounting it (which I'm not brave enough to do), and I can't find the 3dr recommended foam anywhere else except for 3dr (which I'm not suffering the ordering process and costs for from europe).
I've just bought some of the HK orange foam (about £2 incl delivery here in the UK) which I'm going to use to mount my X2. Will let you know how it goes.
on both vehicles with auav I hard mounted their cases and I find vehicles responsiveness and autotune results to be way more accurate and precise.
inside of the case I use a thin layer of soft foam to wrap corners and secure it in the case to prevent direct contact of the board with plastic case, it seems to work fine.
it gives you more pain to tune and balance motors and props, but, it pays off. foam and platforms on bobbins mask the issue but do not fix it, yet, an original 3dr gel is claimed to be quite good too.
Rate Yaw P 0.86??? And i thought mine was high at 0.7
this looks a lot like nor cal coast, is it?
No it's the southeast coast of Sweden.
Problem on optical flow with APM rev 3.3rc8
Dear Friend,
in last week we are testing the APM 3.3rc8 on VR Brain 5.2 , we are checking all nuttx driver and advanced functionality like Optical Flow loiter and lidar terrain following functionality.
So about the lidar we are very happy ... did a lot of test and all work fine as you can see in this video:
https://youtu.be/XXTeOogVd8k
After the test of alt hold we start to evaluate optical flow , follow the wiki instruction did the first fight well and check the log ... then activate the optical flow , armed the drone in stabilize , because in loiter the pre flight check tell that is not possible without 3D fix .. then switch in loiter and try to take off. When i'm taking off i check if the command on roll and pitch work well but it don't work ... don't move the drone ... only throttle work if i re switch to stabilize i re take the control on pitch and roll .
What could be the problem ? Are there some guys that sucessfully check this release of firmware with Optical flow ?
Thanks in advance
Roberto
Could someone point me to a thread or just know off hand the differences between using autotune_aggr .1 to .05?  Feeling a little stupid here, but I don't get it lol!
Wes,
The larger of the two logs is from an AC3.2.1 equipped vehicle.  It shows a climb with the classic symptoms of a vehicle with very high vibration: increasing altitude but negative climb rate.  This impossibility shows inertial nav is confused and that's why it climbs.
The 2nd log is an AC3.3-rc8 log but it's not of an actual flight.  Maybe it's the wrong long?
