Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
The release is in the air... ;-)
BTW, had another crash copter on 3.3-RC8. It's Pixhack too.
It's quad V-tail. Fly good in stab and Althold but after few minutes its made crazy and go to ground in angle ~45 rgad.
Log in attach. I think this because high vibration too.
Still wait for RC9
Yes, extremely, extremely high vibrations on that one.
Anyone able to advise on this?
Nice video!!!
Amazing. Those motors sound lower than 300kv.
I could be wrong, but isn't the GPS settings overwritten by the AC code when booting? So it seems the code itself must be edited to accept the desired changes.
They are unless you remove the RX pin from the GPS lead
A while back there was chatter about the X series of receivers from FrSky transmitting out of band and affecting some GPS units. Do you happen to have one such as the X8R? If so maybe moving the RX as far away from both the GPS and GPS leads as possible and see if that doesn't help mitigate the issue.
Before Mission Planner was displaying PDOP but instead of just changing mission planner to "say" PDOP they change ArduPilot to instead read/display HDOP and I'm not 100% certain they have it right yet.
Well it does have over 400 log files :)  Guess that makes me a log hoarder.
But the AUAV-X2 has over 200 and works fine.
Seems like the Pixhawk has always had trouble pulling logs via MP though. I may format the SD card and reload, but will first clear out the log files.
Randy,
     I was in the process of reviewing some VIBE_X/Y/Z data from some recent flights when i noticed mission planner reporting that I was using flight modes that were not selected during the flight. This problem has only occurred using RC-8.
My Tx is setup to only use Acro / Stabilize / Alt Hold flights modes using a 3 POS switch. When reviewing the flight in mission planner it claims that i've used Guided / Circle / and Manual modes repeatedly in flight while none of them were selected nor reported from MP's spoken voice...
Link to .bin file
https://drive.google.com/file/d/0By12f3-1EZywc3BRVUpPY0VubWs/view?u...
Link to .bin file
Secondly when lowering the ATC_ACCEL_P_MAX and R_MAX values what is presumably the lowest these values can safely go? I have manually tuned my multi to ~0.35 Rate P for roll and pitch while lowering the ATC_ACCEL values (Currently ATC_ACCELL_P/R are 20000 down from autotune set value of 96000). The overal flight experience is fairly smooth but i'm worried as of to the minimum value of those parameters and what may happen if they go to low? Is this an indication of a severely overpowered multi?
Also, Has anybody figured out what good values we should expect to see while using the new Vibe tab in 3.3? my Acc values are fairly low (using the vibration drop down menu) however the VIBE graph from RC3.3 looks far worse in that bin file. Are there certain frequencies / conditions that are not picked up on 1 that the other tab can see? Comparing the above graph from this one highlights my concerns
Maury,
The flight mode thing is certainly a mission planner issue.  Most likely it's confused as to whether the log is an Plane log or a Copter log.  When I open the log I only see Acro, Stabilize, and AltHold flight modes.
Those vibration levels are great!   It's mentioned on the Measuring Vibration wiki page but in short, below 15m/s/s is good, Above 50m/s/s is bad.  Clipping is bad.  Your vehicle is averaging about 4 or 5m/s/s and no clipping so very good.
