Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Brad,
It sounds like an issue in one of the GCSs.  I'd guess the mostly likely culprit is AP2 followed by Tower but that's purely a guess based on how much testing and how many users the platforms get.  It could be MP.  If you can reproduce it or narrow down which GCS did it then we should file a bug report in the issues list for the offending GCS.
with only 1 gps system is very dangerous to fly. I had to put 2 gps units for this reason alone, as it is highly unlikely for both healthy GPS units to glitch with data transfer simultaneously. both vehicles I have are flying very reliably with dual gsp setup. without it - it would do a similar uncontrollable slip out sometimes, same as you saw.
only downside with 2 GPS units is when signal is not good and one gps get replaced with an another your drone may 'jump' to the different location and then back, as it thinks it got moved as different gpc units receive slightly different coordinates.
but it is a minor issue, and I do not think any system on 3.3 should be operated with a single GPS, as long as code is what it is.
Randy stated above drone is expected to land - it does not. it will go sideways as described, with crazy speed, and you need to have a motor kill function ready to stop it from a fly away. it never happened to me after I got dual gps setup done.
PS. Perhaps, for a dual GPS setup it would be nice to augment the code with some analysis of what coordinates each GPS unit reports and prevent this position adjustment done with a presumption that drone suddenly teleported itself from an old location into a different one.
Randy, Thank you very much for your reply. I had just reinstalled the MP to make sure that I had the last version. Actually I have the version 1.3.31 and the Flight Mode AutoTune do not show up on the Flight Mode list. And also is not mentioned on the Full Parameters List. Attached the screenshot. Should I have to open the issue on Mission Planne GitHub? Another question: The ESC calibration method is changed on AC3.3 rc8? I
Sorry for double message.
I have some browser problem in editing the last message. I'm very sorry =(
I re-write evrything here:
Should I have to open the issue on Mission Planner GitHub?
Another question:
Can I calibrate the ESC in the same way I do with AC 3.2.1?
When do you plan to fix this? This is easy. Annoying to see it every time ...
It uses a flight mode.  Initially, setting the flight mode directly didn't work correctly as some required initialization and cleanup wasn't done but that was fixed a while back.  I haven't checked lately, but last time I looked, this needed better documentation in the wiki.  It is important for people with 6 channel radios to be able to set it up this way.
One small restriction with using the flight mode switches;  I believe you need to arrange the flight modes so you can go directly between altitude hold and autotune modes without a third mode between.  For example, if more than one switch is used to select flight modes, you need to be able to switch between autotune and altitude hold by changing just one switch and if it is a three position switch, one of the modes must be the middle position.
--Brad
Thank you. Looks like we posted at the same time :)
The GPS glitch behavior you describe is quite different than what i saw this week, which Randy graciously pointed out were caused bad parameter settings.  I'm still investigating how they got set to 0.
I used to have frequent problems with GPS glitches.  I moved the GPS up and farther away from the rest of the electronics and haven't had a single glitch since (perhaps 40 flights).
--Brad
Thanks for looking into it Leonard. Without a gimbal attached I'm sure the autotuned values from 0.05 would be appropriate, but with the gimbal attached, my big copters (6kg t960 and 7kg s900) always seem to need a manual reduction in the PIDs after autotune to stop shaking. I'll give them a retune with rc8 and see if there's any difference from the tune I got out of rc7.
Yah it's been that way for a while and should be an easy fix for Mr. Osborne but I have a feeling he has his hands full just keeping up with all the changes in the RC firmwares :)
Yes, that's right.  It is actually a flight mode in AC3.3 (in AC3.2.1 it was not a flight mode).
Just reran the autotune with RC8, and it looks to have given me a good set of PIDs on the s900 with aggr 0.05. It looked pretty hairy when the yaw tune started, gave big wobbles on roll, but sorted itself out by the end. Will try on the T960 shortly too.
