Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hi Andre,
The problem is you had your aggr set to 5 not 0.05. This means you were working with 0.2.
let me know how you go with the correct setting.
Sorry for the late reply!!!!!!
Hi Gregmaan,
I could go down to 0.02 maybe on the aggr number but I will only officially support 0.05 to 0.1.
I can't go any lower than roll/pitch 36000 and Yaw 9000. Any lower is just too slow for someone not expecting it. You can set them lower manually though.
Sorry for the slow reply!!!!
Thanks Edwin and Henri!!!
Hi Maury,
The high yaw numbers shouldn't be a problem. This is the big change for 3.3. The Yaw controller is different. You may want to try doing the autotune on yaw set to 0.1. If you want to use the 2.2 parameters you need to increase
RATE_YAW_FILT_HZ to 20. It is currently very low so you may try just increasing it to 4. (I would autotune with aggr of 0.1 though).
I can't seem to actually see your oscillations in the log you sent.
Let us know how you go!!
Hi Fnoop,
0.5 is way too high, that will be limited internally to 0.2. I hope you meant 0.05 but it is worth checking you didn't make a mistake.
My suggested range is 0.05 to 0.1.
Hi Nathaniel,
Sorry for the slow reply.
Your pitch oscillation may be caused by the copter trading off speed for height. This can happen if you ask for too high a speed or if you have a head wind.
You didn't seem to have a navigation log in there so it is hard to confirm.
Hi Pritam,
That is definitely a terrible tune on pitch!!!
Do you have a log?
I would suggest resetting your pitch parameters and redoing the pitch tune. You may need to increase the aggr to 0.1 for pitch. You can do just the pitch by setting the Autotune_axis to 2.
Hi Maury,
You can go as low as you like with the ATC_ACCEL parameters. They only change the handling characteristics. So if you are happy with your copter feeling like an Avengers aircraft carrier then that is fine. Just be mindful that your copter will be slow to react!!
Hi DG,
If you are talking about how the copter flies after autotune then:
Make sure your RC_Feel is 25 or 50.
You can also drop your ATC_ACCEL parameters.
If you are talking about the way the copter twitches during autotune there have been a bunch of tweeks done so I would expect there to be differences.
Hi Paul,
Could you provide a log so I can see your parameters and what is happening.
Hi Leonard,
  I'm talking about how it flies after AT. Even at hover it twitches; looks and sounds awful. I'll get the AT log and post.
Sure.
Here it is. I had to switch off hi rate logging as Randy suggested to try to fix GPS issues, it seemed to help.
If you look at vibrations graph you can see how after 3:30min mark IMU Z accel goes crazy.
It is what it does at descent. No idea why, it was a relatively calm day.
If you want the video you can also hear what motors are doing, it does not seem to be normal, IMHO.
