Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Austin,
For the GPS issue, as part of setting up the optical flow sensor did you set the EKF_GPS_TYPE parameter?  If yes, maybe setting it back to "0" might get it working again.
I had changed the EKF_GPS_TYPE parameter back to 0. It failed to even show stats about the GPS, i.e. Sats, hdop, etc.... After that didn't work, I actually went one step further and used a beta param file I saved from before I configured the OF, when the GPS was working, and reloaded that. No dice. Even reflashing the firmware to the same beta firmware didn't help. The problem only resolved when I reflashed to 3.2.1. I will see if I can get the logs for you.
I agree with Thorsten that it's likely caused by the buzzer.  At the moment that the vehicle switches modes the Z-axis accelerations on the two IMUs separate.  The MPU6k thinks it's falling, the lsm303d thinks it's climbing.  This is the 3rd incident of this now, makes me think we need to change the tone of the buzzer.
just remove the buzzzer :)
in any case we receive all the relevant info via telemetry either on  MP or tower...
after more than a year of using pixhawk I can say that buzzer is more of an annoyance than help.
I removed it on the third day and never used on any subsequent  installations.
p.s. I do not use safety button either :)
A picture of the buzzer mounting distance from the pixhawk in the attachments.  Its a little disassembled but I'll put it back together the way I had it and test it without the buzzer connected.
Thanks Marco,
   Maybe  "out of sync" was a bad term. Very twitchy is more like it. If I reload the previous parameters from the 1" smaller props, it's better.
I've seen others speak of settings to try prior to AT
The motors are KDE 2814XF-515. AUW is 2679. 14x5.5 Gemfan CF is slightly over powered, 15x5 T-Motors are more.  It's just odd that after AT it behaves so badly; never had such a difference.
DG,
     I'm using those same motors with 12" carbon props and Afro 20A ESC on a 6S and they tend to get slightly warm lifting 3500g AUW. I can only imagine the power being put out with 14in Carbon blades. Are you using a 6S also?
What brand speed controllers are you using?
Lowering those settings i mentioned worked wonders getting mine stable. Hope you figure out whats making yours act weird.
I didn't see your post....thanks, that's what I recall reading but it got lost in the posts...will definitely try that.  The copter is using HobbyWing Quattro 4-in-1 ESC......best ones out of 4 tested.
I've used several different props depending on AUW and just plain experimenting, but not 6s....it's actually less efficient than 4s on these motors.
With Gemfan 14" CF, AUW 2679, the quad will hover over 40 minutes @3.6v lowest cell on landing with 16A Lumenier 4s battery. g/W=9.3 which is way above eCalc's estimate of 7.39 as is the hover time. I think it can touch 10 with enough tuning etc. Tarot CF props were horrid (flexing).
APC 14x5.5 drops to 8.7 g/W, but the weight is 2770 due to the adapters.
The motors barely get warm with either, and the copter scoots punching the throttle. With a 12A battery it really goes. With 8A and smaller props it flat out screams.
The Spy 750 Y6 it also has the 515's (HobbyWing XRotors) with T-Motor 15x5. Plenty of power to spare and cool as a cucumber. The most stable prop combo was Xoar 15x5 top and 14x7 bottom (bought 14x8 also but chipped one so didn't try them), and very steady on fast descents.  However, the T-Motors have so far been the most efficient.
Here's the vibration levels with the Gemfans
But it took a lot of work to get those Gemfans balanced LOL (yes that is solder wire embedded in super glue soaked velcro).
Bottom line is the T-Motor's are no heavier than the Gemfans, so I think the AT has changed from when originally done and now I need to massage some settings to get it right. It's only a temporary install anyway, but would like it to fly decent before switching back. If I put the 14's back on and it still flies funky after a new AT in rc8, no doubt in my mind it is changes in AT.
I had a similar issue with the proximity of the buzzer to the Pixhawk. Thorsten and Randy identified the problem (I moved the buzzer a few inches). Note that the problem of interference between buzzers and gyroscopes is being studied. See here: http://www.cio.com.au/article/581231/sounds-can-knock-drones-sky/
HI Devs,
Has something changed with MAVLINK from 3.2.1? I have a an app that works perfectly on an APM3.2.1, but on my PIXHAWK running 3.3rc8 it doesn't get the correct descriptions for the flight modes; although it will still switch them.
Any thoughts?
Cheers, Mike
Randy,
what is interesting is that it seems not to be direct vibration in this case. In one of my logs I saw the buzzer tone in the mag data. So maybe it is magnetic interference. Or sound pressure - which is vibration again...
It gives you additional safety. Depending on the telemetry allowed you can have signal loss from time to time. And in this case I am happy about any buzzer response.
