Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Thanks. I've always done as I said though and it has always saved the new pids. But I will leave AT enabled and land and disarm as that is your recommendation.
What is the bitmask if I want to do say pitch and roll in one shot and then yaw on the 2nd lipo?
Hi Craig,
That would be 3 and then 4.
Hi Scott
What you describe does sound like what is happening to me. On arming, and at first spinup, It sometimes jumps into the air before I am ready, or it may tip  over immediately on arming.
There is that critical moment when the attitude of the copter is in its side that things can quickly go very wrong as the copter attempts to right itself by going to full throttle. There probably will not be enough time to reach for a cutoff switch to stop a out of control multi rotor before it could easily do bodily harm if you (or others) are in its path.
Perhaps some logic code could detect that situation and shut down automatically.  That would be a very good safety enhancement worthy of adding to the code.
On Arming you can control how the props spin. In my personal case I regulate that to the lowest possible velocity that the combo ESC/Motor has a steady spin and it's low enough that no propulsion is generated.
https://youtu.be/ec6srDAq2EE?t=22s
U
se MOT_SPIN_ARMED to control how fast the props spin on Arming. Some have the Mot_Spin_Armed disabled, but I really like it because the speed is not enough to cause damage
Hi Richard,
Sorry for the slow reply.
There are a number of issues here. First up your hover throttle is too high, you hover at approximately 350 but you have your hover throttle set to 460. This will result in your copter jumping if throttle up while it is on a slope and also make it difficult for you when you touch down on landing.
You also have very high vibrations. This will impact your Alt Hold performance and tend to cause the copter to wonder in altitude.
Looking at your crash, this looks like you attempted to disarm the copter before the copter had detected a landing. You pulled the roll to the left, pitch down and yaw to the left. The copter then looks like it followed your commands. You then switched to RTL but by this time it looks like it had take a couple of knocks and no longer able to stabilize itself.
I am sorry about your crash and hope this helps!!
Hi Leonard. Can you check my post on Autotune a couple of pages ago? I think we can get good info from you. Thanks!
Is there any way RC10 would shut down the servo rail?  My 1300 X8 is dead after going from RC9 to RC10.  RCin and RCout track in MP.  The ecs's operate fine with channel 3 direct from the receiver.  But when I attach a servo analyzer to the servo rail of the controller and arm, there's nothing.  No PWM what so ever.
BTW, check the other outputs other than 1-8 and they're all good.  Just 1-8 is dead.
Just ignore this post.  OMG, not getting enough sleep!  I'm sure you can guess what I forgot to do lol!
Safety switch? :) Been there done that :)
Disable it to hell, so annoying :)
when is the super extended logging going to be taken off override? the log files are huge and cant input them to exmaps website, it hangs reading.....
