Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Don't know. It's always a case by case that has to be "traced" :) In this case it might be just a glitch because the other power parameters don't show anything:
Tried Auto mission today with tower and could plan the mission but could not take off.  As soon as I touched the Auto takeoff button the copter switched to auto mode and shutdown.  It worked just fine using the transmitter.  This worked with the previous version of 3.3.
I also think my Pixhawk is going bad as when I first plug it in I get bad AHRS.  If I unplug the unit and plug it back in it's fine.  It only does this the first time I use my IRIS.
Program a switch on your remote to be emergency motor stop.
I have serious issues w/ the landing detection, and my copters flip over, or bounce, or try to take off again, or simply don't slow their motors fast enough when landing.  I broke props almost every time I landed.  Now, I set it down, hit the motor kill switch, and everything is fine.
Hi VP,
Not sure what you mean about the bitmask, I recommend using 157693.
You are correct about the axis numbers.
Hi Scott,
I love it too :)
To complete my tests of 3.1.2 to 3.2.1 to 3.3-rc10's Auto tune I need a little help with 3.3-rc10
3.1.2 took about 3 minutes so 1 battery is fine. 3.2.1 took about 8 minutes so one battery barely made it. Now 3.3-rc10 is going to take even longer and my beater quad only gets about 10 minutes on a battery so I need a little run down on how to do it on 3.3-rc10. I know you can set a bitmask to only perform part of the test but my question [which I asked about 100 pages back] is how do I know that particular part of the test is complete and do I do the same as before which is once it is complete I turn off auto tune, switch to stab, then land and disarm. Is it the same now? Will it just stop doing the dance so I know that part is complete and then I do the same then switch the bitmask for the rest of the tests and repeat?
Hi Swift,
You can use a X or a H frame type depending on the direction you would like your motors to spin. If you have any twist in your frame at all you will get significantly better yaw performance if you use a H frame setup. That diagram you show is attempting to tell you you should use an X configuration if you have a layout like the copter on the left of that diagram.
I got that every now and then on rc-9 but do not seem to get it on rc10. Also after you unplug your lipo use a paper clip or something to short the leads on your connector to fully discharge your MR as some have said this solves the issue.
It is my understanding (and experience) that seeing "bad AHRS" on startup is due to the momentary lag as EKF is starting up (mine always clears momentarily) . I only started seeing it back when I first started EKF logging.
Hi Craig,
Set Autotune_Axis to 1 for roll, 2 for pitch and 4 for yaw.
Run through it normally, the copter should stop twitching and give you a tone to let you know you have finished.
You should never have turned off Autotune as that means your values aren't saved.
When Autotune finishes, simply land without changing mode at all or switch to Stabilize and land. Only after you disarm should you turn Autotune off. You can then carefully take off to test your tune of that axis. You can then change batteries and your axis to tune and repeat.
Thanks. I've always done as I said though and it has always saved the new pids. But I will leave AT enabled and land and disarm as that is your recommendation.
What is the bitmask if I want to do say pitch and roll in one shot and then yaw on the 2nd lipo?
Hi Craig,
That would be 3 and then 4.
