Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I have a dumb question.
I finished the 3.1.5 and 3.2.1 on the 1st hawk lite today but now I am going to do the 3.3-rc10 but I need a howto on the auto tune for 3.3.
On 3.1.5 AT took just a few minutes so I was able to complete on a single battery [2200mAh 4S]
on 3.2.1 AT took a LOT longer and it was a little windier so I wasn't able to do it all on the first attempt but was able to complete on a 2nd attempt [less re-adjusting]. Now it seems that since 3.3 adds yaw that there is no way I will be able to run all 3 axis on a single battery and I see you can set to test whichever axis you want once or two at a time what is the exact processing doing so.
When I do the AT on 3.2.1 and older, it does the tests and then stops then I turn off AT then switch to Stab, then land and disarm. What am I to look for if I only do 1 axis at a time? Will it do the dance, then stop, then I do what? Turn off AT and then switch to Stab and then land? How will I know it's done with each "leg" of the test?
I've tested it - none of the rc channel control code was changed. I can confirm all serial mode features work. I haven't tested the gimbal in mavlink mode.  This is with firmware .86e & 3.3rc10. Make sure you set the gimbal mode to rc control, the easiest way is to change the default mode to rc targeting (MNT_DEFLT_MODE).
There are a number of parameters listed on the RTL flight mode wiki page that may help.  So for example, to stop the vehicle from  descending during the land phase of RTL, set RTL_ALT_FINAL to a number > 0.  like 10m and it will stay up there.
I think everyone understands, but just in case, the failsafe radius of 5m is only used to make the decision whether the vehicle should RTL (as the failsafe parameter specifies) or whether it should instead LAND.  So if the vehicle is within 5m of home when the failsafe happens, it will trigger a LAND instead of an RTL.  If an RTL happens, it will still attempt to land at the takeoff location.
The feedback I've received on the previous 2m radius (from a few people) was that it was too small.  There's some discussion of a more complicated decision involving altitude and distance from home but sadly that will need to wait for Copter-3.4.
I think 5m (or 15feet) is really quite a short distance but I must admit when Luis and I discussed it I thought to myself it was perhaps too large.  How about 3m or 4m?  I'm not keen on using WPNAV_RADIUS because I think most people will not expect this parameter to affect the failsafe behaviour so I'd prefer a hardcoded distance if we can agree on one.
Wilson,
Sorry, I actually downloaded your log when you first posted but didn't complete the analysis.
I think the lean is caused by the poor GPS location.  The NSat is really very low at only 5 or 6.  I think the GPS position was drifting around but it wasn't bad enough to trigger the glitch protection.
The EKF also reports a spike in velocity and position variances around that time.  I'm not very familiar with the units of these variances so I've asked Paul Riseborough (EKF expert) and we shall see what he says.
I don't think it's caused by the low battery itself because the desired and actual roll/pitch values stick together.
Use X and it should be front left motor goes clockwise then front right goes counter clockwise then rear right goes clockwise and rear left goes counter clockwise and are ordered as it shows Starting front left  and going clockwise around the frame 3-1-4-2
Thanks Randy for looking into my issue~ ^^
My landing/take-off point has poor GPS reception. This location is surround by tall buildings and a hill of 100~200 meters height. So I switch to alt-hold mode when I attempt to take-off and landing, expecting to be unaffected when my copter is flying through this "bad GPS air-space".
Does autopilot or EKF continue to use GPS information in alt-hold mode or land mode, maybe for correcting X-Y coordinate?
Thanks a lot for your help again~~
I must say my initial tests with 3.3-rc10 running totally stock everything on my beater quad with a Hawk Lite is one of the better firmware revisions I have run in a really long time. Rock solid. Alt-Hold is working well, Loiter is back to being like it is hanging from a string and RTL worked flawlessly each time I used it. Awesome work!
Use of WPNAV_RADIUS does make sense to me, especially since the other WPNAV_ parameters control the return speed, etc.   But I think the more important issue is *why* is land being performed at all if RTL is the selected failsafe action?  As you mention, land may not even be configured as a part of RTL if RTL_ALT_FINAL is not 0.  So if it's not zero, why land just because the failsafe happened to occur within a 5m radius of home?  Shouldn't we be going to RTL_ALT_FINAL instead?
I'm guessing the motivation for land if inside WPNAV_RADIUS was just an easy way to avoid wasting power climbing to RTL_ALT only to decend and land again later (in the default case where RTL_ALT_FINAL=0)
I see this as a safty issue.  If RTL_ALT_FINAL is greater than 0, it may be because it's pilot control is the only safe way to land.  If so, failsafe should not land, no matter where it happens to be when failsafe kicks in.
--Brad
Hi! This is a question specially for Leonard and I think and the answer might be a good addition to the Wiki.
Let say I have a copter that I know the PID should start at 10 for stabilize Pitch and Roll and 0.25 for Rate Pitch and Roll. I remember that those values are near the previous ones that I had on the same copter but I had to clear the eeprom and I forgot to back up :-(.
Does it help and speed up the process if I start with that?
Maybe this can be extended to a second autotune if the values that are setted in a previus one are not too accurate?
Thanks so much for the help
I had a very violent crash today while flying my 750 size quad.   I am currently using 3.3rc8 on this one.
I have flown it about 3 times on this firmware and it was very stable.  The wind conditions were light and variable.
this time, I began to wonder when I first tool off, a slight gust came up and It tipped over backwards.  on a second try, it lifted off and seemed very stable (in stabile mode).  I switched to Alt-Hold at about 10 feet, it seemed to be fine so I went to PosHold.
Also fine, but I was showing friends how it could hold position then it started loosing stability in the Z axis.  It dropped i altitude pretty quickly and I took a bit of stick to stop the descent.    I stopped so I tried to get it to stabilize, flipped it back to Althold.
then I decided to land, and forgot it was in AltHold. It landed and I reached to switch it back to stabile, and the copter spun up again, tipped back, then went to full throttle.  I was about 20 feet away and I started to duck, but it went but me so fast I didn't had time to take cover, I was just blessed that it missed me.  (this is a 6s powered system with 15 inch carbon props, and 380 Pancake motors and it is lethal at full power.  It then headed towards my group of 5 friends and just by the grace of God missed them too. it was all over the place, ended up reversing course several times, barely missed me again on the way to destroy my ground station and finally hit some pavement, flipping a few times until it slung the battery off.
All this happened in about 2 seconds..
Once I was able to declare it officially dead, I started picking up the pieces.
I feel that the beginning of this sudden destruction was cause by landing in Alt-Hold.  Is that possible?
here is the log, I hope someone can help me understand what pissed this copter off.  I'm afraid to power this beast up again..
(there is a lot of dead time where I am waiting for GPS lock and getting the ground station set up)
Hi
Besides what has been said by Trent Russell there's something very strange on your vibration log that occurs right after you said you changed to PosHold. If you see the clipping that jumps at that time, I would say that something physical came loose and from that point forward the copter was trying really hard to keep up.
I know that now might be almost impossible to trace back where the physical fault might have occurred but look carefully at what might not be crash results.
Sure, plain APM Planner 2.0.18
