Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Josh,
The GPS driver starts at 38400 but it does try various baud rates if it doesn't find a GPS.  I've never tried it myself to be sure but Tridge and Michael DuBreuil who know more about the GPS driver tell me this.
Good advice!
IvanR,
Thanks for the report.  That really does look pretty terrible with the vehicle oscillating quickly in roll and pitch at a couple of times in the flight.  I suspect reducing the WPNAV_ACCEL to 100 will help but it's current value of 200 doesn't seem high enough to cause this problem.  I'll have a chat with Leonard about this and get back to you.
Thanks Randy for your explanation.
So is it possible that when failsafe-land kicked in, I was actually fighting with the EKF/GPS? Maybe EKF/GPS was pushing the copter forward and my RC2 was pulling the copter back?
If this is true, I think the situation maybe avoided as follow.
- in failsafe-land mode if there exists pilot input on RC1/2/4, stop listening to EKF/GPS and listen entirely to the pilot input
- in failsafe-land mode if there is no pilot input, listen to the EKF/GPS
That is giving pilot command the highest priority if EKF/GPS and pilot are both "talking" to the autopilot at the same time. With this my copter would have entirely listen to my RC2 pitch-back and wouldn't lean to the front by itself.
If it takes 12 months and 50 RCs to get a stable and reliable release, I'll gladly wait and keep flying 3.2.1.  Last thing I want is a FCS that I cannot trust or that crashes my birds due to errors or bugs.  I'm fully capable of doing my own crashes without help from an unreliable FCS.
Hi ,
The “ping-pong” between 2 GPSs is old (not a rc10 issue) .....  I don’t have the logs anymore, but from August I removed the second GPS from my Quadcopters…. The Crash is really difficult to happen, but happen in different conditions.
http://diydrones.com/forum/topics/copter-3-3-beta-testing?commentId=705844%3AComment%3A2068761
IvanR,
Leonard and I had a look and we suspect the EKF is having some problems with the altitude a climb rate estimates.  Vibrations are a little high including a small amount of clipping during the time of sever oscillations.  Of course we're not sure how the flight controller is mounted but you might want to try isolating the flight controller with the 3M foam or hobby king orange foam if you're not already.
Also we have a few suggestions for tuning changes for the alt hold controller:
  • reduce VEL_Z_P from 6.0 to 5.0 (the default)
  • reduce ACCEL_Z_P from 1.0 to 0.5
  • reduce ACCEL_Z_I from 2.0 to 1.0
Could you give these a try and see if it helps?
I found my mistake: From the wiki it is not clear if we must disable the mavlink heartbeat for using serial protocol. With the older versions it works with the enabled mavlink heartbeat. But with the newer storm versions you must disable it to get serial protocol working. Maybe the serial setup should be explained a little bit better in the wiki.
Many thanks
Gregor
Great you found your issue. About the Wiki though, since it IS a Wiki you are free to sign up and make edits which frees up the devs time to actually do devvy working you know. Just saying.
Did you try doing a esc calibration after the update and before you changed you mot_spin?
A bit of a question here: has the way RSSI being reported in the mavlink been changed in 3.3? I have a strange issue when I setup up my RSSI pin 103 and range 3.3v MP shows correct rxRSSI, however minimosd shows constantly 0. I roll back to 3.2.1 and I get RSSI back, while with exactly the same settings RSSI is 0 in the minimosd while correct value in MP. Please advise.
So is the two GPS issue solved in rc10 or is it safer to run with only one?
