Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
IvanR,
It's off in -rc10.  It was actually only in -rc7 that it was forced on.  Hopefully you can reduce the logging from "IMU_FULL" to just "IMU" with the MP's checkboxes for LOG_BITMASK.
Scott, Richard,
honest feedback is fine.
If you guys have logs we can have a peek as to what's going on.  As Richard describes there is a moment when the pilot throttle passes 25% (or 1/2 of mid throttle) where we suddenly turn on the attitude controller.  Leonard and I have a patch that attempts to smooth out the transition but it's a AC3.4 fix.
Thanks Randy, I'll give it a try!
The 10m range is a bit arbitrary.  We could reduce it to a smaller number, if it's too small though then I think it will cause problems when landing close to home.  I think the pilot will find the controls moving around as they land.  How about 5m?
5m is better than 10m for sure. What is important in my opinion is to figure out why sometimes invert of controls gets stuck when vehicle moves out of that zone back to where it was.
That was it.  Just had to raise the throttle up to about 50% and both chutes eject perfectly.  Hey, one other question.  The hud never displays level.  It's always leaning over like 5 degrees no matter how many times I calibrate.  Any ideas?
Have you tried the new(ish) ACC Calibration button for Level?
No.  I thought it was a shortcut (as in not as good) for the 6 axis calibration.
Pretty sure that is why it says "Calibrate Level" and the one above it says "Calibrate Accel" :)
I could be wrong though, but I take it to mean pretty much what is says and it's for leveling the controller on frame :)
As far as I understood it is sort of a trim which adds to the absolute level I.e. when your FC is not totally parallel to the propdisc
Here's my dilemma.
I have a Pixhawk that continuously throws up BAD GYRO HEALTH.
And even though my Tarot 650 is perfectly still, the HUD is jumping all over the place.
Some times even goes upside down, etc.
I've seen uTube vids of this problem since 2013.
I'm sure this could be due to a faulty board.
But never-the-less, the problem seems to be very common.
Now here's the interesting thing.
I installed firmware 3.1.5.
And just like that everything is working perfectly.
Then I tried v3.2.1 and the latest 3.3RC10.  With the exact same problem.
Reading through the release notes, I see that the secondary gyros have been activated as of v3.2.
Looking at my lives stats I can see that gx,gy,gz are relatively still, but gx2,gy2,gz2 are jumping all over the place.
This is why I came to to the conclusion the board is faulty with the secondary gyros.
My questions is...I can use the Pixhawk with v3.1.5, but I was to use the latest firmware.
So how can I de-activate the secondary gyros, so that it behaves like v3.1.5.
I'm sure a lot of people will find this to be a solution to boards that are out of warranty.
Maybe try INS_USE2 set to 0?
I see now it can be set to a 3rd Gyro as well, maybe we can now use an off board gyro?
