Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
no idea sorry.
Nathaniel,
appreciate your reply and I truly respect all the good work of the developers and beta testers to create a high quality product.
Please allow me to raise one observation after following this thread over the past months. In my view the software got too complex in the meantime, the increasing number of copter config options and to be supported 3rd party devices and clones is compromising speed of innovation.
In my view 3DR made the right decision to split the Arucopter code for Solo, otherwise this great product would have missed the market opportunity.
So I shut up here and put my Pixhawk project on hold and patiently wait for the release.
In the meantime I enjoy my new Solo :-)
Best Stephan
these threads are always long and hard to sift through if you are looking for something specific, but that applies to all forum/blog type discussions. I personally don't think the release cycle is that long given how many new features are implemented. Also compare to some other open source projects which normally are a right mess of code and bugs. In this regard APMcopter has come a long way in the last two years. If you don't want to risk testing betas, stick with the old stable version and wait. I found, especially with 3.2 and 3.3, that I could fly all release candidates without being overly afraid of bad things happening which was not always the case in the past. So I think the dev team is doing a really great job here!
Randy,
Since the Wiki doesn't fully explain how to use the Auto tune in 3.3 could you please explain some things.
I understand that it is a flight mode and needs to be entered from a single switch throw from AltHold?
How does one save or discard the Autotune?
What is the suggested starting value for Autotune_AGGR.  I have seen some using .10 and some .05; is there no in between?
Hope to try this out on my deadcat  tommorow.
Thanks,
Greg
http://copter.ardupilot.com/wiki/autotune/
The wiki pretty well covers it.  I don't know about Autotune_AGGR though.  It recommends a range of somewhere between .10 and .05 though.
-Mike
After autotune is completed:
Land with autotune on and the settings are saved.
Land with autotune off and the settings are discarded.
Note that mission planner will tell you, "saving autotune".
As for aggr..  Still not really sure.  I know that at .1 my copters are pretty skiddish.  At .05 they're doggy lol!  I need to do more testing.  BTW, all my copters are 960-1300mm hex and X8's.  Not to mention 7 to 18kg, so my findings probably don't mean much.
Stone,
The wiki makes no mention of autotune now being a flight mode it still makes reference to ch7/ch8 so I don't think it covers it very well.
 This information may be more accurate but I can't confirm it.
http://diydrones.com/forum/topics/copter-3-3-beta-testing?commentId...
So it would be nice to hear the definitive answer from one of the developers.
Shaun,
When you say land does that include the requirement to disarm to initiate the save?
Greg,
Yes, you'll need to land and disarm while still in AutoTune (i.e. ch7/ch8 switch high or flight mode set to AutoTune) to save the gains.  I've slightly updated the "Changes for 3.3" section of the AutoTune wiki page.  Hope that helps a bit.
Certainly we need to add the ability to start/stop/monitor AutoTune from the GCS in future versions of the software.
First practically trouble-free flight with v3.3rc10, an AUAV-X1 flight controller on a small carbon tricopter.
I did notice however that I could arm and fly without a GPS lock at all despite ARMING_CHECK set to 1 (enabled), is this normal?
3.3 RC-10 on "true" Pixhawks with linear dc voltage regulators. (LDO)
Tested on two very different multi rotors.
a) small 500 mm (19.5 inches) quad.
b) medium 1 meter (39.37 inches) hex
They both have frame that don't flex and CF propellers so no fluttering or other kind of prop vibration.
Used the level acc calibration prior flying.Then flew very short time to have a precise view in the log file of the
CTUN (THR_OUT) value that I copied in THR_MID. (I still don't know why this isn't an automatic feature).
Anyway on both these aircraft I tried to:
- take off stabilize
- take off in alt hold fly and land
- take off in Loiter fly and land
Never been so "locked in" even some wind was pushing the aircraft down.
A Heaven for camera handling. Was wondering why I used a 3 axis gimbal with vibration dampening! :-)
As this is before auto tune, I really wonder if I should go through the auto tune ?
Will try longer flights, missions and spline way points tomorrow.
If all goes well, I'll try RC-10 on a medium size (1.2 meter) quad X8 configuration.
Just a note: Prior take off, in Loiter mode, I checked on the telemetry laptop (rfdesign.com.au RFD900+ radio modems) HDOP and numsat which were very good (see log screen below).
@Shaun Bell: +1 (For size and weight) So at least we are two LOL LOL LOL
My tiny "beating" Quad is 500mm and used exclusively to test new RC-x version.
When things looks "~ok" then I try on real heavy lifters!
So don't feel "alone" ! LOL :-) and your findings often match mine. :-)
Kind regards
Henri
