Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Richard: We do! The full-time wiki editors are paid 3DR contractors, and they make dozens of improvements each day. But even they can't do everything themselves (this is a free and open source project, with hundreds of contributors), so to keep up with the community code development we need community documentation contributions, too.  Please consider helping out by joining the maillist here
Ok a follow up to my Hex issues.I've attached the logs and here is a screen cap of the flight from mission planner's point of view.
I can fly it but it's just all over the place. Motors are making some jerky sounds and it's just insane to fly it.
I thought it might be the 13 inc props so I put a new set of balanced 12x3,8 on it [didn't help at all].
It has brand new motors so I don't think they are causing the issue though I had a pal rewind and rebuild my old set so I'll try those when they get back. The only thing "old" on the hex is the ESCs and they are a couple of years old :( So I am wondering if maybe they are the cause though they and the old motors were totally fine before I benched it.
Please help me figure this out as it is really frustrating.
Oh and another thing the hawk is the same one I used on the beater quad for the tests I posted a few days ago and it had 0 issues
+1,  same history with my older cuad, waiting a Pix this week if solve the problem, only esc are going to be old (I didn't ask for replace ones :( ) I follow your issue (I build another cuad that flies nice), yes, very frustrating.
Done. Thank you.
@ Craig: Lots of X vibrations indicated, and the red Compass bar all the time.
I did shake this time my AUAV-X2 (foam pad mount)strong movements with -rc10 onto DJI F450 and this looks a lot better than yours:
Maybe you should work on your vibration damping.
Thank's for the video Gervais, I think's that my problem is still there too so I'm waiting for another dampening system too, new graphs looks amazing to evaluate; I'm anxious to give a try.
Is the AUAV-X2 officially fixed in rc10? Sorry if this was already answered.
Should be..  Test it, and let us know :)
A couple weeks ago I mentioned my copter drifts a lot when between (rather than above) trees, but with ~15 satellites and a low HDOP. M8N GPS.  Someone asked for a log, and I finally made one.
I'm not sure it's an issue, as the copter is definitely stable above the trees.
But if you want data, here are some logs.
I also had an attempted fly-away, on rc10 in loiter.  It was the first time it's ever happened to me.  Historically, my copters have all been very stable once up in the clear sky.
I'll post a link to my attempted fly-away discussion, in case anyone working on 3.3 wants to see those logs.
Attempted fly-away
I've attached an image of the amount of drift over a couple of minutes, while the copter is actually stationary, and a log.
I didn´t even notice that there was a problem, till I read about ;-) Although I tried about most -rc. I just put the 1k resistor on and forgot about it. Since I´m not a battery endurance tester anyways, I still don´t even care about it.:-)
PS: Btw., the recent batches (so called "quiet" version w/o TI) are coming with the mod already,if I understood Nick correctl.
It looks like it is stuck trying to upload the log... I'll try again.
You didn't understand him.. .
Mine is new, quiet version, and his "fix" is this, copter 3.3.   Nothing changed on the hardware, but he sure is saying it's "fixed".
