Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Tags:
Looking at the Alt hold performance on a breezy day for RC10 it looks like the Alt graph line is following the DAlt better than the BarAlt. does this mean the accelerameters are out performing the Barometer under these conditions or is it an avalible trust issue making Alt look better than Baro Alt?
What could be done to improve the alt hold in this case?
Just for reference I will post the IMU, Vibe and RCO graphs.
Hi Henri,
Autotune only saves if has completed the tune. That means it needs to successfully complete all requested axis before it will save the tuned pids.
Hi Greg,
Sorry to hear about your burnt ESC. I don't believe there is anything that has changed that could cause this to happen.
Hi Wes,
DAlt is what the controllers are being told to do. Alt is the estimated altitude the controller is using and trying to make equal to DAlt. BarAlt is the raw output from the Baro before it is combined with the accelerometers.
I believe we can do better in this area than we are currently.
Last weekend we had our first relatively still day for a while and I thought that I would try autotune again. My previous attempts failed - ran out of battery before finished. I have three quads, a 450, 500 and 550 all now with -rc10 installed and I set the parameters to do just the roll axis on each. The smaller quad ran out of battery after 7.5 minutes without completing roll AT. I normally only ever fly it with that size battery, would a tune with the larger battery needed to complete be valid for the smaller/lighter battery that I normally use? In the case of the 500 quad the roll AT finished near the end of it's second battery (10.5 min). I ran out of time to do any more.
I have a couple of questions. Given both that AT now seems to take materially longer and my recent understanding that each axis is separate, is there a case for automatically saving the "tuned pids" after each axis is complete and then commencing the next AT attempt from the start of the next axis to be done? There may have to be a new parameter value or some other means for the user to tell the AT process not to start again from scratch, but this could be setup at home and then the AT process completed at the flying site without the need to modify the axis parameters between attempts.
Secondly, the time taken to complete each axis has obviously increased, more so if the craft needs to be re-positioned. In a ten minute per axis AT attempt, re-positioning will be needed, I suspect, no matter how still the air. I'm wondering if there is anything particular the user can do in respect of pre-autotune setup to reduce the amount of time needed to complete the process?
Hi Mike,
It is not normal for Autotune to take so long. Can you show me a log?
Hi Greg,
Sorry about your crash....
I had problems with Qbrain in other platforms (32 bit boards.)
I spent one month to understand the problem….really hard….…. After more than 20 crashes, I simulated the problem on the ground …. With physical support one axis platform
And the problem occurs without “loops” too…. With fast commands
So.... maybe is a similar problem.... “frequency”… I don’t know…
and with old APMs boards no problems....
Video with Q Brain (look the video description) 1 year ago….
https://www.youtube.com/watch?feature=player_embedded&v=yKyrdje...
Video afters change Q Brain
https://www.youtube.com/watch?v=sRT8Hpk0kqU&feature=player_embe...
@leonardthall
Please could you confirm:
example:
Bitmask: 0:Roll,1:Pitch,2:Yaw
VALUE MEANING
0 None
1 Roll
2 Pitch
4 Yaw
If I select only the roll axis (1) to be auto tune. Then subsequently take off in alt hold and activate autotune until it finishes this axis, Following land and disarm. Is the new PID for this selected roll axis stored or not?
Thank you.
Henri
Hi Henri,
Provided you have not turned autotune to the off position then it will be saved.
If I recall correctly WPNAV_UP and _DN used to control the climb rate in althold, this no longer seems to be the case in v3.3, what controls it now?
Stock flashes, no BLheli.
Both HW ESC's are using Intermediate timing. High timing does increase RPM at full throttle.
Pardon, I should have addressed this question to Greg, it is very common for both SK and blheli ESCs to heat up like crazy even at 5-6 amps with pancake motors even though hardware is rated to 40amps... haven't seen stock HW firmware doing this.
45 members
1472 members
282 members
470 members
57 members
Powered by
