Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hi Randy,
Have we got any closer to what to do with this issue?  I understand that the message is ambiguous in APM:Copter V3.3-rc10 but I have not been able to find a way out of it.  Do you have any suggestions as to how to track down why EKF is unhappy?
I have tried disabling PreArm checks entirely and thepre warning message persists.  The LED shows flashing blue when any GPS-reliant mode is selected prior to attempting to Arm. In Stabilize mode (as expected) the status LED is green and arming is possible.
I have on occasion seen the Pixhawk status light go green in GPS (Fence enabled) mode if I wait long enough.  Yet the HUD says 3D fix and Sats are >= 6.
this worked great for me, solve the problem plus love the enhancements!!
Hi Randy...I will make the suggested changes and give it a try, the Pix is mounted on one of these (link below), not sure I can try something better...I have always struggled a bit with minimizing vibes on this copter (Tarot 680). Winds are calm today so it wont have the same issue, but they should pickup tomorrow again....thanks a lot for looking into, you guys are awesome!
one more thing, should I try AUTOTUNE first also?
http://www.amazon.com/Flight-Controller-Anti-vibration-Damping-Abso...
log from burn up
tune file too large to load
How heavy is your copter? I've found those Qbrain ESCs to run very hot on 4s, maybe the autotune just pushed it over the edge?
I'm running a 4 x 25a esc on a test copter at the moment, and at an AUW of 2kg, and 20A total draw at hover, the ESC gets uncomfortably hot after a 10 minute flight.
Glen,
I have no way to weigh the quad but it should be close to the 2kg mentioned.  Others flying with full FPV that mine lacks are about 2.2 kg.
It flew fine for about 8 months and autotuned in 3.2.  Since changing to 3.3 I have now lost two motors (just found one on closer inspection) and two 4-in-1 escs.
So uncertain what the issue(s) is.  3.3, undersized escs or two bad motors.  There are quite a few quads with the Tiger MT4006s motors using 4-in-1 escs.  Most of them are using the Emax 25a, but it doesn't play well with the Pixhawk.
@ Greg
I believe that when you land and disarm you "accept the auto tune" and these values will be used onward. (this is why some people, including myself, just do one axis at a time.)
You said " Decided to land and disarm due to low battery warning." So good or bad you saved the new PID values at that point.
I could be wrong but it worked that way until RC-8 or 9.
Perhaps you could place back your saved parameters before this auto tune and do one axis at a time.
Henri
@Henri
Are you suggesting that doing the 3 axis at one time stressed the esc and that doing one at a time would avoid this?  Steady flying to low battery warning didn't seem to cause problems in the past.
No I am suggesting that doing one axis at a time give generally enough time for a battery to do so.
- So you take off in alt hold activate auto tune with your pre programmed switch.
- You land and disarm (that save the "auto tune" PID for this axis.)
- Placed a new  "fresh" charged battery ready for next axis.
- Using Mission Planner, change the next axis you want to "auto tune".
And you do the same for the 3 axis.
Regards
Henri
I am using HobbyWing XRotor on one Y6 with KDE 515 motors, and HobbyWing Quattro 25A 4-in-1 ESC on a quad with the same KDE motors. Both work very well with Pixhawk and remain cool, even the Y6 with them installed in the arms. HW is the ESC of choice for me now.
Y6 AUW: 3.2kg
Quad AUW: 2.7kg
That after trying Maytech ST and ZTW Spyders unsuccessfully. The ZTW is now on a quad that seems to work ok, but on the Y6 I couldn't get 6 motors to spin to save my life. It was a real stumper why they wouldn't work. If it was an issue with Pixhawk, the reason was never discovered.
I'm now building an X8 which will likely use the same KDE 515 motors and two HW Quattro ESC's. On 4s these motors are flat out beasts; haven't found another that can compare yet. HLY, SunnySky (not saying they aren't good motors) and several others just don't have the horsepower and get too hot on 4s when AUW exceeds 2.5kg or so with say <600kv.
The only issue remaining is getting the tuning perfected. It's close, but not quite there; after 1 1/2 years using AC I still haven't tried to learn how to play with PID's very well, and now there are several other variables. "Auto" is such a nice sounding word.
Off my soapbox now.
On my 800 class X8 I use RCTimer 30A opto escs and they works awesome.
http://rctimer.com/product-1059.html
Although my motors are only 750kv I don't get any heat or sync issues what so ever and loaded, with gimbal and batteries weighs in about 3.6kg, I also use 4S and really can't find fault with these ESCS and they are cheap to boot :)
I personally would not think of using 25A escs myself let alone quatros as I would hate to have "1" go out and loose the ability to use the other 3 :( Just my opinion.
